Re: schooling on set cam and crank timing
[Re: buildanother]
#867214
11/30/10 01:50 PM
11/30/10 01:50 PM
Posts: 606 Montana
Yancy Derringer
Montana
And when both dots are at 12 oclock, set distrib at #1 cyl firing.
This is an important point. It's obviously more accurate "to see" lining up the cam at 6 o'clock and the crank at 12 o'clock
THIS POSITION is no6 ready to fire. So all you REALLY need to do--if you don't rotate the engine afterwards---is to drop the dist in pointing to no6
easy
[Re: MoparforLife]
#867216
11/30/10 05:28 PM
11/30/10 05:28 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
I know Don, but many novices wrongly assume cam dot at 6 oclock, and crank dot at 12 oclock, means it is setup for #1 firing. That screws up many minds.
[Re: buildanother]
#867217
11/30/10 05:56 PM
11/30/10 05:56 PM
Posts: 606 Montana
Yancy Derringer
Montana
Years ago a customer brought in a Ford Y block out of an old boat. The rebuilder went through the engine and the owner could not get it to fire. Finally asked me to take a look. Turns out the installation was reverse rotation---that is until the rebuilder got done.
Yea, my mind was screwed up for just a little while
[Re: Yancy Derringer]
#867218
11/30/10 06:24 PM
11/30/10 06:24 PM
RapidRobert
6 & 12 o'clock lets you use a straightedge whereas 12 and 12 o'clock would not (crank snout in the way) and I have no clue as to why cams are not ground so that is #1 compression like most people assume it is and I have yet to see a manual that tells you that it is on #6 firing & not #1 and way back I lost a pole position because we couldn't figure out why it would not fire and I could not get back out onto the track in time
