How Fast Can You Go With A Hydraulic Cam #866781
11/29/10 09:09 PM
11/29/10 09:09 PM
dusterjp Offline OP
dusterjp  Offline OP
A body owners. How fast has your small block gone with a hydraulic cam. As much detail as possible please.
Re: How Fast Can You Go With A Hydraulic Cam [Re: dusterjp] #866782
11/29/10 09:13 PM
11/29/10 09:13 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Seen falt tap hydro's do 10's in an a-body. I'm sure a well preped 440 w/ a 509 could get ya there.
Coming soon!!!!
Re: How Fast Can You Go With A Hydraulic Cam [Re: Mr.Yuck] #866783
11/29/10 09:27 PM
11/29/10 09:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I know of a 440 E-body that ran 10.60s years ago with a hyd cam, 7200RPM somehow.
Re: How Fast Can You Go With A Hydraulic Cam [Re: topside] #866784
11/30/10 02:41 AM
11/30/10 02:41 AM
gregsdart Offline
gregsdart  Offline
Pretty much how much you want to spend to get the performance. A basic hydraulic deal can go nines in a 3000 lb car with the right big block stuff. I went 10.10 at 131 mph with a 268 @ .050 .540 lift juice cam in a 12.5 to 1 compression 475 inch BB with 440-c unported heads, and a 750 alky carb. Weight was 3180. A bigger carb, more compression, porting and maybe schubeck lifters and some big springs to make it rev and it could have gone mid nines with a longer duration higher lift cam.
