Re: 1/2" fuel pickups
[Re: kensmachine]
#866480
11/29/10 03:38 PM
11/29/10 03:38 PM
Posts: 43,161 Bend,OR USA
Cab_Burge
You've done better than I have, I ended up taking my stock pick up(1971 Duster) to a local hot rod fab. shop and they removed the stock pick up and duplicated the bends with a stainless 1/2 inch tube and silver soder it back in the stock location They even attached the sending unit like it was stock so it reamined in calibration IHTHs.
[Re: kensmachine]
#866481
11/29/10 04:22 PM
11/29/10 04:22 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Unless that thing has a SERIOUS motor, a 3/8" line will be plenty.
[Re: kensmachine]
#866485
11/30/10 01:46 PM
11/30/10 01:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
yes I know I would have to change the fuel line to 1/2" you dint read my whole post Witch I do the samething from time to time. yes we think that the 3/8 pickup and line is enought but if we are going to the work to change the whole system its only about $75-100 more to with 1/2" why not go over kill. Ken
I made plenty of 1/2 picks when I worked in the fuel lab for Chrysler... if you have a bender you can do it BUT when soldering it back on to the plate watch out that you dont over heat/burn the isolator for the gauge you cant get them
