Here are my current specs:
74 Cuda with a 360,
Eddy torker II intake,
Eddy torker Plus cam,
The specs are as follows:
@050 Int dur. 222 , Ex dur. 234
Lift Int .447 Ex .450
Intake Centre line 107 Ex centerline 116.
About 9:1 compression.
Holley 750 vac secondary carb.
Dizzy has been recurved, running 20 initial, 38 total all in before 3000.
727 with stock converter (I know -its on the list!)
8-3/4 with 3.22s
I have been thinking for a while taht I may go to a dual plane intake (eddy perform RPM) and a matching cam to make the car a little more streetable (move the powerband down a bit as it is a bit of a dog under 2000 rpm).
I was looking at the Performer RPM cam spcs, and it is not much different from what I have now.
So if I put on a good dual plane intake, would that improve the overall streetability of the car, giveign it more power down low????
Any thoughts woudl be appreciated.
Thanks,
Jason
