Who makes the replacement motor mounts for the 440's that have the integral "Lock design" that keeps the engine mount from seperating in the event that the rubber fails? I need a complete set including the rear trans mount. Would you recommend using a uerathane mount or ?.
I also need a torque strap for the engine that will bolt on without any major mods. Any suggestions - even your own designs or ?
Car is a power steering car.
Anyone have any suggestions?
Last, does anyone besides TTI make a mandrel bent exhaust system that is a complete bolt on system that has an "X-Pipe" design? This will be for use with Factory cast iron exhaust manifolds.
Where can you get the lowest prices on Dynomax Ultra flow mufflers?
Thanks Moparts,
Bogusracer
