-16 single oil line Jeff from MCH mentioned #866253
11/29/10 03:19 AM
11/29/10 03:19 AM
WI.
Scotts71chall Offline OP
WI.
On another post Jeff mentioned he used a -16 single external oil line. I would like a picture and what parts/pickup he used, AN fitting # and line routing, line coming from top or bottom into the pickup.
For a world hemi block, stock high volume pump, motor plate, dragster style pan, MF k-frame.
Thanks!
Re: -16 single oil line Jeff from MCH mentioned [Re: Scotts71chall] #866254
11/29/10 01:55 PM
11/29/10 01:55 PM
WI.
WI.
Anyone else set up like this?
Re: -16 single oil line Jeff from MCH mentioned [Re: Scotts71chall] #866255
11/29/10 02:54 PM
11/29/10 02:54 PM
organ
maximum entropy Offline
organ
i'm running mancini's single line static set up on my car. it has a spacer that goes between the pump and the block. it works very well. i did port the spacer, and i routed the external line low all the way to the pump (below oil level in the pan). it primes instantly, and i've had no issues whatsoever.
Re: -16 single oil line Jeff from MCH mentioned [Re: Scotts71chall] #866256
11/29/10 04:44 PM
11/29/10 04:44 PM
detroit area
moderncylinder Offline
detroit area
i used a -16 to -12 steel fitting and drilled it through to .750 or whatever it was at the -16 end,,, screwed one fitting in my pickup, which is -12,, and another in the milodon pump plate which is -12,,, then made a -16 line with a 90 on the pan and a 45 on the pump
