727 tranny linkage #866133
11/29/10 12:27 AM
11/29/10 12:27 AM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
The small block is now in the car and I'm trying to hook up the tranny linkage. There is a bracket on the linkage that bolts to the tranny (pic)except that it does not seem to fit. A 904 came out, a 727 went in, what bracket do I need?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: 727 tranny linkage [Re: busboy] #866134
11/29/10 12:29 AM
11/29/10 12:29 AM
busboy Offline OP
busboy  Offline OP
One more.
Re: 727 tranny linkage [Re: busboy] #866135
11/29/10 12:37 AM
11/29/10 12:37 AM
busboy Offline OP
busboy  Offline OP
Oops, forgot to compress them. Here we go again.
Re: 727 tranny linkage [Re: busboy] #866136
11/29/10 12:38 AM
11/29/10 12:38 AM
busboy Offline OP
busboy  Offline OP
One more time.
Re: 727 tranny linkage [Re: busboy] #866137
11/29/10 05:00 PM
11/29/10 05:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Because the 727 case is wider the torque shaft (Z-bar) and the bracket are different, you'll need to find the correct 727 parts.
Re: 727 tranny linkage [Re: John_Kunkel] #866138
11/29/10 09:08 PM
11/29/10 09:08 PM
busboy Offline OP
busboy  Offline OP
Ok, thanks John. Anyone have this linkage for sale? It's for a small block 727 column shift Dart.
Re: 727 tranny linkage [Re: busboy] #866139
11/29/10 09:30 PM
11/29/10 09:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Put a want ad in the correct location but don't hold your breath waiting for a response , not many A bodies had a 727 and column shift so it's a rare part .
There is another thread on here from within the last week with some tips to modify what you have to fit .
Re: 727 tranny linkage [Re: JohnRR] #866140
11/29/10 09:32 PM
11/29/10 09:32 PM
busboy Offline OP
busboy  Offline OP
Whoops, sorry about that. I'll put the request in the right place and hunt for that thread, thanks
Re: 727 tranny linkage [Re: busboy] #866141
11/29/10 10:24 PM
11/29/10 10:24 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
I swapped trans between 904 and 727 many years ago in my 67 Cuda. I was able to make the same bracket work by putting the stud in the other way, and putting the bracket on the other side of the mounting ear, or something like that. Look it over, and think about it.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
