727 tranny linkage
#866133
11/29/10 12:27 AM
11/29/10 12:27 AM
Posts: 670 Third rock from the sun.
busboy
The small block is now in the car and I'm trying to hook up the tranny linkage. There is a bracket on the linkage that bolts to the tranny (pic)except that it does not seem to fit. A 904 came out, a 727 went in, what bracket do I need?
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: 727 tranny linkage
[Re: busboy]
#866137
11/29/10 05:00 PM
11/29/10 05:00 PM
Posts: 25,852 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Because the 727 case is wider the torque shaft (Z-bar) and the bracket are different, you'll need to find the correct 727 parts.
[Re: busboy]
#866139
11/29/10 09:30 PM
11/29/10 09:30 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Ok, thanks John. Anyone have this linkage for sale? It's for a small block 727 column shift Dart.
Put a want ad in the correct location but don't hold your breath waiting for a response , not many A bodies had a 727 and column shift so it's a rare part .
There is another thread on here from within the last week with some tips to modify what you have to fit .
[Re: busboy]
#866141
11/29/10 10:24 PM
11/29/10 10:24 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
I swapped trans between 904 and 727 many years ago in my 67 Cuda. I was able to make the same bracket work by putting the stud in the other way, and putting the bracket on the other side of the mounting ear, or something like that. Look it over, and think about it.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
