Fuzzy magnet? #865929
11/28/10 10:03 PM
11/28/10 10:03 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Dropped the pan on the transmission in my 93 W250, no huge amount of deposits noted but the magnet at the bottom of the pan is loaded with small particles that kinda look fuzzy once disturbed. Yeah, I know it's because the particles are so small and obviously magnetically permeable, I'm just unsure if the amount is normal or not. The truck has ~ 120K on it, lots of use with a snowplow, so mild abuse at least; to my knowledge the trans has not been opened up before but don't know for sure. Trans is a 42RH/A518. Dropped the pan for a look-see since it's been whining very loudly and getting worse - sounded exactly like a hydraulic pump with no fluid to pump, so I was thinking possible clogged filter. Filter doesn't look great, but not as bad as I was expecting.
Thanks,
Mike
Re: Fuzzy magnet? [Re: 1E2C] #865930
11/28/10 10:12 PM
11/28/10 10:12 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
I'd say that looks good/normal for the mileage and condition you describe. Wear on the steels is normal- it's chunks/chips of metal you don't want to see.
Re: Fuzzy magnet? [Re: In_The_Pink] #865931
11/28/10 10:25 PM
11/28/10 10:25 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
There were a couple small chunks in the pan, didn't think to check them for being magnetic or not, may have to do so, but it was only 2 or maybe 3 small pieces I saw.
Mike
Re: Fuzzy magnet? [Re: 1E2C] #865932
11/28/10 10:38 PM
11/28/10 10:38 PM
Amherst,NY
challengermike Offline
Amherst,NY
If it has a whine i would think somethings coming apart.
Re: Fuzzy magnet? [Re: challengermike] #865933
11/28/10 11:07 PM
11/28/10 11:07 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
As long as the whining is coming from the right side it can simply be ignored....Uhmm...You are married ,right?
Re: Fuzzy magnet? [Re: Bill MeLater] #865934
11/28/10 11:12 PM
11/28/10 11:12 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Yeah, I'm married.......... good thing she doesn't read this board.
But, this truck is for working with that snowplow, so she doesn't get in it too often.
Nice idea though.
Re: Fuzzy magnet? [Re: 1E2C] #865935
11/28/10 11:19 PM
11/28/10 11:19 PM
Wisconsin USA
Wisconsin USA
Sorry I can't offer real help, don't run any automatics myself. Did you try a Google search?I've had fair luck with similar problems.
Re: Fuzzy magnet? [Re: 1E2C] #865936
11/29/10 12:05 AM
11/29/10 12:05 AM
MN
astrobuf Offline
astrobuf  Offline
MN
Nice idea though.
Read it again, I think you missed the joke!
Whining coming from a tranny, (as opposed to the right seat) is due to a chipped or otherwise damaged gear tooth. Once it starts, it snowballs. I'd advise shopping for a replacement.
Astrobuf
So, are you really a Rocket Scientist?
Re: Fuzzy magnet? [Re: astrobuf] #865937
11/29/10 09:47 PM
11/29/10 09:47 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Yeah, actually I did get the joke and a good laugh when I read it. I was kinda trying to keep it playing by pointing out it's a work truck so she doesn't ride in it... Truth is, I had to share your response and my reply with her since I knew she'd find it funny also, was good for another round of laughs. (Took two tries to get a good one, but I'm gonna keep this one.)
Mike
Re: Fuzzy magnet? [Re: 1E2C] #865938
11/29/10 10:48 PM
11/29/10 10:48 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
And I was gonna say if you've got a whiney tranny in your truck maybe you should try a different dating website...obscure, in poor taste, but I couldn't help myself!
2 Demons...no, not my kids!
Re: Fuzzy magnet? [Re: 1E2C] #865939
11/30/10 09:58 AM
11/30/10 09:58 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Do the bands ( if any adjustments on them...), change the fluid and filter and you should be good to go. Just make sure you put the correct fluid in it as Mopar got real picky about which fluid to use. I had plenty of Chrysler automatics whine a little when either low on fluid or needing a band adjustment. That little bit of wear you see with the magnet is nothing - don't sweat it at all. Just did a 32RH in a 96 van that would whine and slip a little when starting off on a hill. Band adjustment fixed it.
The page below (when it loads...) may have the specs you need...
http://arrc.epnet.com/autoapp/9107/9107CH07_ADJUSTMENTS.htm
Re: Fuzzy magnet? [Re: Sixpak] #865940
11/30/10 10:53 PM
11/30/10 10:53 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
90% of the time a trans whine its because the filter is restricted. Some dont even look that dirty but I find the filter is it most of the time. I have also had clogged coolers cause this. The whine is from the pump trying to suck the fluid in or pump it thru the cooler and converter. Once I had a pump cause a whine also. Ron
Re: Fuzzy magnet? [Re: 383man] #865941
11/30/10 11:25 PM
11/30/10 11:25 PM
Amherst,NY
Amherst,NY
whine can be caused by a few things,a bad torque converter,a bad pump,low on fluid, and If its when its moving it could be the plantaries.If the filter is pluged its because theres something coming apart.And thats alot of materal from something.Post pics of the magnet,it will be real easy to tell if the trans needs a rebuild.
Re: Fuzzy magnet? [Re: challengermike] #865942
12/01/10 12:10 AM
12/01/10 12:10 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
See the first/original post.
Re: Fuzzy magnet? [Re: In_The_Pink] #865943
12/01/10 12:32 AM
12/01/10 12:32 AM
Amherst,NY
Amherst,NY
OOPS,i read it yesterday and didnt reread it before i posted again,lol.Looks like a decent amount of metal on the magnet.some is normal but i think that looks to be more than normal.
Re: Fuzzy magnet? [Re: challengermike] #865944
12/01/10 03:13 AM
12/01/10 03:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
With the milage you have on it thats normal. Of course you will have clutch material from the converter clutch and the tranny clutches in the filter that you cant really see from normal wear at 120k. I have seen this many times before. Change the filter and fluid and get another 30k out of it. I see tranny's look like that at 30k with just tiny particals that are normal. As long as its no bigger pieces then I would service it with a filter and let it go. Ron
Re: Fuzzy magnet? [Re: 383man] #865945
12/01/10 11:44 PM
12/01/10 11:44 PM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Yeah, think I'm just gonna set the bands as long as it's apart, clean it all up and bolt it back up. We'll see what happens next........ Oh, here's a shot of the filter, of course it's still draining, makes for a bit of a gradient look to the media.
Mike
Re: Fuzzy magnet? [Re: 1E2C] #865946
12/01/10 11:57 PM
12/01/10 11:57 PM
that's what I'd do, ch filter/fluid/adj bands/clean pan. Holler how it turns out. Filter looks bad, hope that takes care of it.
Re: Fuzzy magnet? [Re: RapidRobert] #865947
12/16/10 12:35 AM
12/16/10 12:35 AM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Well, finally back together with new filter and bands adjusted per the FSM and took it to work today. It's still got a little bit of a whine on acceleration which is louder when it's cold, (was ~ 9 degrees when I left this AM), but quiets some after getting to operating temperature. Barely noticeable at steady cruising, so that's a significant improvement. It also seems to shift a bit smoother, so overall I'd say it was worth the effort.
Thanks for the input, all.
Mike
Re: Fuzzy magnet? [Re: 1E2C] #865948
12/16/10 12:46 AM
12/16/10 12:46 AM
Northern MN
1E2C Offline OP
1E2C  Offline OP
Northern MN
Just for gits-n-shiggles, this is the rig I've been cussing the most lately.....
