Installing a timing tape... Harmonic balancer sizes? #865464
11/28/10 10:55 AM
11/28/10 10:55 AM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
We are installing a timing tape on the balancer this morning. I have a factory steel crank balancer on the 340. I have a cast crank balancer on the bench for easy measuring, and it measured 7 1/4 inches. As my installed balancer is very difficult to measure, would it be the same diameter? I just want to make sure I use the correct tape. We took a circumferance measurement on both balancers and they seem to be the same...but I would prefer to know for sure before installing.
Re: Installing a timing tape... Harmonic balancer sizes? [Re: Lew] #865465
11/28/10 11:06 AM
11/28/10 11:06 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
7.25" is correct.
Nautilus Racing-
Re: Installing a timing tape... Harmonic balancer sizes? [Re: Chris2581] #865466
11/28/10 11:16 AM
11/28/10 11:16 AM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
Thanks a ton!
Re: Installing a timing tape... Harmonic balancer sizes? [Re: Lew] #865467
11/28/10 12:40 PM
11/28/10 12:40 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
get it very clean use alcohol. installs left to right.
