Challenger Trunk Texture coat? Also seam seal question #865211
11/28/10 12:07 AM
11/28/10 12:07 AM
Canal Fulton, (Akron) Ohio
Q
Quicksmopars Offline OP
Q
What texture coat should I use for the insides of the quarter panels? I've tried a couple but can't seem to duplicate that factory texture.
Also if anyone knows of any tricks for making the seam sealer in the trunk look factory, please let me know. Thanks.
Re: Challenger Trunk Texture coat? Also seam seal question [Re: Quicksmopars] #865212
11/28/10 12:19 AM
11/28/10 12:19 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
What gun are you using to spray product in the trunk? I've used rubberized undercoating, petroleum based undercoating & truck bed liner all with decent results, the key is a large enough undercoat gun & playing with the air pressure..
Re: Challenger Trunk Texture coat? Also seam seal question [Re: 1_WILD_RT] #865213
11/28/10 07:46 PM
11/28/10 07:46 PM
Q
Q
What gun brand do you use? I'm assuming an undercoat gun is different than a regular paint gun with a big tip?
Re: Challenger Trunk Texture coat? Also seam seal question [Re: Quicksmopars] #865214
11/28/10 07:57 PM
11/28/10 07:57 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I use a Sata, the pickup tube is 1/2" id & the spray nozzle is about 5/16" so yeah it's different from a regular paint gun with a big tip..
Mine is much older but looks like this
http://www.sata.com/index.php?id=1529&L=18
Re: Challenger Trunk Texture coat? Also seam seal question [Re: 1_WILD_RT] #865215
11/29/10 02:19 AM
11/29/10 02:19 AM
Q
Q
Ok, I see now, definately way different than a paint gun! Thanks for the response Wild RT.
Re: Challenger Trunk Texture coat? Also seam seal question [Re: Quicksmopars] #865216
11/29/10 05:47 AM
11/29/10 05:47 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Re: Challenger Trunk Texture coat? Also seam seal question [Re: autoxcuda] #865217
11/29/10 04:21 PM
11/29/10 04:21 PM
Q
Q
Good links! This will really help me give my car an original look in the trunk I'm looking for.
