High Stall Converters and Highway Driving??? #865129
11/27/10 11:16 PM
11/27/10 11:16 PM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
I get tired of conflicting info.
I've read on here that it's fine to run a tight converter rated at 3000 stall on the streets, roads and highways. Talked to someone today about running a TC with about 3000 stall who said that it would be too high for highway driving. That it would generate too much heat. That I should keep it down to no more than a 2500 stall TC. This person has been racing and custom building engines for like 40 years. I'd like input from you all about this subject.
I'd like to run a 3000 stall TC. I'm running a 727 with 3.73 gears. The cam would love it.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: High Stall Converters and Highway Driving??? [Re: Junky] #865130
11/27/10 11:21 PM
11/27/10 11:21 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
USING a good quality converter ...NOT to worry
Re: High Stall Converters and Highway Driving??? [Re: Junky] #865131
11/27/10 11:25 PM
11/27/10 11:25 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Your friend is still stuck in the sixties.
I'm running a 4800 lb C-body with a 493 727 3000 Turbo Action converter with 3.23 gears. ZERO problems.
Install a good quality trans cooler and enjoy.
With 3.73's it would be locked up freeway speeds anyway.
Kevin
Re: High Stall Converters and Highway Driving??? [Re: Junky] #865132
11/27/10 11:25 PM
11/27/10 11:25 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
you'd need to do some calculations, including exact tire height and rear gear ratio. As long as your highway RPM's are higher than your stall speed, you will not generate excessive heat. I.E. Highway RPM's at 3500, not so much heat. Highway RPM's at 2500, there would be heat caused by slippage in the converter, and more heat generated as RPM's decrease. Install a big trans cooler and go for it!
Shop carefully for your converter. They will need all kinds of precise information to get you the right converter (it must work with your cam selection for optimum results). If you provide them with bad info (or they never ask for detailed info) you will not get the full bang for the buck and may be unsatisfied. The wrong converter can make the car a dog!
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: High Stall Converters and Highway Driving??? [Re: Junky] #865133
11/27/10 11:26 PM
11/27/10 11:26 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Just do it. I ran a 323 geared 440 B body all over the joint with a 10" turbo action, factory radiator cooler only, never burnt trans up. It won't be slipping too bad to pull your B body around under minimal load. I could not say the same thing if you were hauling a 5000 lb or more trailer, up a steep grade for many miles though.
Re: High Stall Converters and Highway Driving??? [Re: Junky] #865134
11/27/10 11:28 PM
11/27/10 11:28 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I agree with the above posters on running a quality unit PLUS a tranny cooler.
I run a TA 10" tight unit now for 5 years on the street with 3:91's and 27" tires (3500rpm unit) and no problems so far. I also have a temp gage so I can watch the running temp of the tranny with the converter. Call Paul Forte at Turbo Action and he will ask for all of your info.
Junky:
With your new cam, I would bet that you won't be able to wipe the smile off of your face if you went with a 3k+ converter.
With all of the bolt on items that I have thrown onto my car in the last nine years(5 carbs,2 intakes, 2 cams, 2 ignition systems, even 340 HP manifolds to TTI headers[second place!]), this 3500 converter is by far the most "seat of the pants" improvement that I have seen.
Re: High Stall Converters and Highway Driving??? [Re: buildanother] #865135
11/27/10 11:29 PM
11/27/10 11:29 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
Re: High Stall Converters and Highway Driving??? [Re: Twostick] #865136
11/28/10 12:04 AM
11/28/10 12:04 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Unless you are really on the throttle the converter will be pretty much locked up anyway. (At least as locked as it will get)
Re: High Stall Converters and Highway Driving??? [Re: slantzilla] #865137
11/28/10 12:35 AM
11/28/10 12:35 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
my understanding is the better converters slip less under light load than "budget" converters. My 9.5" Dynamics converter has a noticeable slip pulling away from a stop sign at light throttle, but by 15 mph or so, it is not noticeable. For the most part, you usually get what you pay for with converters. Not to say that some brands may be over or under rated.
Re: High Stall Converters and Highway Driving??? [Re: GO_Fish] #865138
11/28/10 12:56 AM
11/28/10 12:56 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I run a 3800 stall 9.5" dynamic - with 3.23 gears - runnin down the highway i get 16 mpg -
before with a mopar 2500 ( 175k ) 10" converter i got less mpg, it spun the engine 400 rpm more at 55 mph and made more heat - a quality converter will work in this application.
I called several, ATI told me i'd never get it done - i called dynamic and they said i could drive to florida and back ( NJ) and they were right - i have over 8000 miles on it now and never had a problem!
Re: High Stall Converters and Highway Driving??? [Re: DJVCuda] #865139
11/28/10 01:21 AM
11/28/10 01:21 AM
crlush Offline
crlush  Offline
Theres no such thing as high stahl street converters, the higher the stahl the more heat it will generate, just make shure you use a good trans cooler and you will be fine, been running a 3800 stahl converter for years with a good trans cooler and have never had any problems.
Re: High Stall Converters and Highway Driving??? [Re: crlush] #865140
11/28/10 01:27 AM
11/28/10 01:27 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
the fin pitch, stator design and construction can essentially make a smaller diameter converter flash AND become efficient at speeds...
picture a pinwheel behind a fan - one will push the other and it will eventually get close to the same speed.
That is a positive pitch on the fins, the old school way to get stall was to put a negative pitch, and it would work against itself never getting efficient. Not anymore.
I put this together a few years ago - might be worth the read.
April / May 2008 Mopar Enthusiast Magazine - Talking Torque Converters
Re: High Stall Converters and Highway Driving??? [Re: YO7_A66] #865141
11/28/10 02:32 AM
11/28/10 02:32 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
OK, I'm confident now to get a higher stall converter. I'm already running a B&M trans cooler. Tires are 28" tall. I'm usually runing 2700 RPM's down the highway or more. I think it's 383man that runs a tight 10" Turbo Action rated at 3000 stall, and he loves it. I'll be looking at that one, but will look into others too.
Junky:
I can't wait.
Re: High Stall Converters and Highway Driving??? [Re: DJVCuda] #865142
11/28/10 02:41 AM
11/28/10 02:41 AM
Wherever I am.
Junky Offline OP
Junky  Offline OP
Wherever I am.
Thanks, good read.
Re: High Stall Converters and Highway Driving??? [Re: Junky] #865143
11/28/10 05:20 AM
11/28/10 05:20 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been driving my 63 on the road since 2006 with a 9.5 Dynamic converter that flashes about 4200. I drive the highway all the time along with the back roads. I drove it to Carlise going up 83 at 60 mph all the way taching about 3300. Its about 90 miles one way. I have not had any problems in my 63 or my boys Dart that has been on the road since 1997 and also has a 9.5 Dynamic unit.
See here I am at Carlisle. Ron
Re: High Stall Converters and Highway Driving??? [Re: 383man] #865144
11/28/10 07:33 AM
11/28/10 07:33 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've driven a heavy '67 Newport with a 3800 Dynamic convertor as a dailydriver for a couple of years.
3.9 gears and a 'happy' 440 under the hood.
Ran the transcooler lines through the extra cooler only.
Re: High Stall Converters and Highway Driving??? [Re: 383man] #865145
11/28/10 07:35 AM
11/28/10 07:35 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
here's my understanding of the topic.
New, high quality torque converters are good for the street, AND will still stall high on the track for good ETs.
remember, it's a TORQUE converter. TORQUE being the key word, not "RPM"
the more torque you put into it, the more it will slip. at maximum torque, you'll get maximum slippage, up to the stall point.
under part throttle, light load cruising, your not really making any torque, and that "high stall TC" is not slipping excessivly --again, at part throttle cruisng.
**Photobucket sucks**
Re: High Stall Converters and Highway Driving??? [Re: 70Cuda383] #865146
11/28/10 08:46 AM
11/28/10 08:46 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
The first stall converter I ever had was so bad I was about ready to give up driving a performance car on the street. It would slip noticeably up to 3000 rpm. I could shift through all 3 gears at 2000 rpm and never see the tach move.
I bought a good converter and WOW the difference was amazing. Not only did I have very firm shifts at ANY rpm (it could bark the tires on the 1-2 shift at 2300 rpm and part throttle), but it flashed on the trans brake to 4200-4400.
I have since had several different converter/car combinations, and always found the ones I ordered for the cars were great, the "off-the-shelf" units - not so much.
Scott
Re: High Stall Converters and Highway Driving??? [Re: Junky] #865147
11/28/10 09:45 AM
11/28/10 09:45 AM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
9.5 3800 Dynamic no problems
Re: High Stall Converters and Highway Driving??? [Re: DAMOPARS] #865148
11/28/10 02:33 PM
11/28/10 02:33 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
Use a good trans cooler and worry about something else that's important. I run a 8" TA that stalls 6200rpm, I drive it everywhere and the closest cruise nite is 30 miles away. Dave
