How fast with a single carter electric pump? #865090
11/27/10 10:34 PM
11/27/10 10:34 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
Years ago I bolted on a Carter competition series black fuel pump and it's still going strong and holding 6 psi at the stripe doing 125 MPH
I have a -10 inlet from the Fram canister filter and have it hardlined with 1/2 line up to the Holley reg.Anyone else take a system like this into the mid tens?
Gus
64 Plymouth Savoy
Dana 60
Re: How fast with a single carter electric pump? [Re: fourgearsavoy] #865091
11/27/10 10:55 PM
11/27/10 10:55 PM
S.L . MI
clutch Offline
clutch  Offline
S.L . MI
The old D100 went 9.80's with one of those carter black pumps. 1/2" aluminum line from front to back.
Re: How fast with a single carter electric pump? [Re: clutch] #865092
11/27/10 11:30 PM
11/27/10 11:30 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
See sig
OOPS, I only have the Mechanical Pump I see this thread is about Electric pumps.
Sorry
Re: How fast with a single carter electric pump? [Re: fourgearsavoy] #865093
11/27/10 11:57 PM
11/27/10 11:57 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
I run just about the same setup . I just had to replace the pump this past summer. Got 14 years out of it and run low 10's with no problem.
