70 swinger hood scoop color #865006
11/27/10 08:22 PM
11/27/10 08:22 PM
New Brunswick
U
Unfair Advantage Offline OP
U
New Brunswick
Are there three "Factory options" regarding color of the scoops ;1}Body color 2} scoops only flat black{or ..organisol ?3} flat or organisol with large portion of the hood painted as well ??
Re: 70 swinger hood scoop color [Re: Unfair Advantage] #865007
11/27/10 08:47 PM
11/27/10 08:47 PM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
Yes, I think you are correct. Mine are body colored.
Re: 70 swinger hood scoop color [Re: 340swing] #865008
11/27/10 10:18 PM
11/27/10 10:18 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The entire hood and scoops are body colored, but if the car had the blackout hood paint option then the middle of the hood and the scoops were painted with organisol. You could not get the car with a body colored hood and black painted hood scoops.
The black paint is centered on the two bumps on the sides of the hood and it runs straight back to the windshield trim. No pinstripes on the edges either.
Re: 70 swinger hood scoop color [Re: Neil] #865009
11/28/10 01:13 AM
11/28/10 01:13 AM
New Brunswick
U
U
New Brunswick
Therefore only two ,options ? Was the paint organisol{textured } or flat ?
Re: 70 swinger hood scoop color [Re: Unfair Advantage] #865010
11/28/10 03:44 PM
11/28/10 03:44 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
This car has the black hood paint scheme correctly done.
As far as I know there was only one type of organisol paint. It does have a light texture to it so using flat or semigloss paint won't look right.
http://www.muscle-car-wallpaper.com/imag...1280x800-03.jpg
