Part number help #864696
11/27/10 12:30 PM
11/27/10 12:30 PM
SE Pa.
LimeliteAero Offline OP
SE Pa.
Im not even sure what to call this part but its on the inside of a 70 Coronet fender, it houses the turn signal bezel assembly.
can anyone get me the part number? It has EMF 785 stamped into it but I dont reconize this as a part number.
TIA!!!
Re: Part number help [Re: LimeliteAero] #864697
11/28/10 10:28 PM
11/28/10 10:28 PM
Ohio
DGE470 Offline
DGE470  Offline
Ohio
The turn signal isn't in the fender on a 1970 Coronet. Do you mean the side marker lamp?
Re: Part number help [Re: LimeliteAero] #864698
11/29/10 01:44 AM
11/29/10 01:44 AM
New York, USA
Chargerfan68 Offline
New York, USA
TIA!!!
http://www.dantesparts.com/sidemarker.html
Scroll down to the 70 B Body Coronet section...Is that what you want??
Re: Part number help [Re: Chargerfan68] #864699
11/29/10 11:15 AM
11/29/10 11:15 AM
SE Pa.
SE Pa.
YES I mis-spoke so to speak! I meant side marker. and the link posted lists the part as side marker backing plate for the Cuda side markers, but the FSM lists it as "bracket". no part listed for the B-bodies.
I attached a picture for reference.
Thanks Guys!!!!!
Re: Part number help [Re: LimeliteAero] #864700
11/29/10 02:16 PM
11/29/10 02:16 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
3403784--right
3403785--left
