68 roadrunner dash color #86460
07/09/08 07:32 PM
07/09/08 07:32 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Someone tell me the name of the black paint on the dash of my 68 roadrunner. THANKS
Re: 68 roadrunner dash color [Re: bobs69] #86461
07/09/08 10:50 PM
07/09/08 10:50 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Referred to as Suede Finish. Jewel Black was the '69 name (misplaced my '68 book, but same color). DuPont #4428L was the code, which may have to be cross-referenced to a current code.
Has about a 600-grit finish, using flattener and experimenting with spraying it on "dry" - hold the gun further away than normal, lower pressure than normal.
Defroster grilles, radio plate & steering column cover weren't painted (molded in color), but steering column & ashtray were same as the dash.
To do the dash correctly, it or the windshield should be out of the car. I always pull the dash out. Which of course means removing the windshield and replacing the seal.
