Re: Project Bad Demeanor
[Re: Hitman340]
#864458
12/04/12 11:50 PM
12/04/12 11:50 PM
Posts: 3,456 Out West
408strokerdart
Out West
Thanks guys. Kenny, That is a glass hood with a carbon wrap.This is something I offer at my shop.
Thanks for the good info Brian. I will be sure to give that a close look. If I run into a issue I may be asking for some of your measurements to compair befor I call them. Thanks again!!!
Just let me know if you need anything.
[Re: lowbudget]
#864460
12/05/12 03:17 PM
12/05/12 03:17 PM
408strokerdart
Out West
Not to bust your bubble Jeff, but I see a problem....maybe. That is the same transmission I run. They forgot to put the "spacer" between the bellhousing and trans case on mine. They made a run of sb mopar bells that were to short and they make it up with a spacer. Now, maybe you have a newer bellhousing since they said they would correct it at their next run of castings. Just check it out....caused me some grief and took lots of measurements to find out it was not my mistake. ATI kept saying I didn't have the coverter in all the w ay.
Thats hilarious, I delt with them over this same issue over 2yrs ago. The very first "adapter" is currently on my car. You would think they would have a clue by now
Mine showed up just like the picture Jeff posted....no spacer. I about tore my hair out trying to figure out what I was doing wrong. With the spacer it went without a hitch.
[Re: fishy340]
#864462
12/05/12 06:48 PM
12/05/12 06:48 PM
Posts: 842 Baltimore,MD
Bill_LBSR
Baltimore,MD
The issue with Lowbudgets car and a few others was ATI cast their small block mopar bellhousings for the powerglide supercase 3/4" too short. Took me 3 months of back and forth with ATI until they finally listened to me and rechecked there measurements and realized it was too short. So they fabbed up a 3/4" spacer between the bellhousing and the case to fix the issue. They haven't made a new run of those bellhousings yet that I know of, because im supposed to be getting one when they do. They want to sell all the short ones before they make new ones and its not like SBM to powerglide bellhousings are something they sell alot of.
LBSR
[Re: Bill_LBSR]
#864464
12/05/12 08:03 PM
12/05/12 08:03 PM
408strokerdart
Out West
You and Brian have me confused what didn't fit? I just got the same trans w a mopar sb bell and all worked and fit great...i just had to make a trans crossmember to work w it
dont how yours worked unless your running a midplate of some sort. Without the spacer I couldn't even get the bellhousing to mount up to the block with the converter in.
I agree. Maybe you can measure the total length of your bellhousing? If it fit (and there is no spacer between the bell and trans case) then they might have fixed them. I would like to have one without having to use a spacer....not sure ATI would be quick to let everyone know it is fixed and they are ready to hand out free bellhousings.
[Re: 408strokerdart]
#864468
12/05/12 08:38 PM
12/05/12 08:38 PM
Bill_LBSR
Baltimore,MD
I'll have to give them a call and see. I figure a free bellhousing is the least they could do for me after doing their R&D work and figuring out the problem for them..lol
LBSR
[Re: B3422W5]
#864469
12/05/12 08:46 PM
12/05/12 08:46 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Boy,
I read threads like this and truly wonder why the Mopar Gods ever saw fit to produce big blocks
they were created to keep weight on the nose and the wheels down lol
[Re: Hitman340]
#864476
05/29/13 10:27 PM
05/29/13 10:27 PM
Posts: 3,395 Pa
Hot 340
Pa
