Tires size and Gear ratio 8th mile #864290
11/26/10 08:17 PM
11/26/10 08:17 PM
Daisyland USA
jnkgal Offline OP
jnkgal  Offline OP
Daisyland USA
tires and gears
need new tires for season and maybe change the gear. what do most of you run right now. presently 4.56 with 31 tall tire to go with the 540 with 4500 converter or should I leave it alone and not change for 8th mile track?
"A goal without a plan is just a wish."
Re: Tires size and Gear ratio 8th mile [Re: jnkgal] #864291
11/27/10 12:01 AM
11/27/10 12:01 AM
Cab_Burge Online work
Cab_Burge  Online Work
I run my car at both 1/8 and 1/4 mile tracks and don't change anything including the tune up, 6:80 in the 1/8 and 10:40 in the 1/4 My car is a street and strip car, not a dedicated race car I have tried three different rear gear ratio in the car with no other changes, 3:73, 3:91 and 4.10 with the same size tires, 30 inch tall radials. car didn't vary .10 ET in the 1/4and .25 MPH between all three ratios My motor is a 4.300 stroke 400 block that is 518 C.I., low compression on pump gas motor only
Re: Tires size and Gear ratio 8th mile [Re: Cab_Burge] #864292
11/27/10 12:10 AM
11/27/10 12:10 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
An option, find the correct gearset that works with both tall and short slicks, we used to run the smaller dia in the 1/8 the larger in the 1/4..but that was a long time ago.
Re: Tires size and Gear ratio 8th mile [Re: jnkgal] #864293
11/27/10 12:36 AM
11/27/10 12:36 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Hi,Jnkgal! I would go with 30"-31" tire again,and keep the 4:56 gear...if you're revving 10% over your peak power rpm in the 1/4 mile! BTW...NICE SELF PORTRAIT! Looks like you're making a wise choice in professions,also! My wife's been an RN for 20 yrs...VERY GOOD job security! Good Luck with your schooling! Remember this fine work of art you did for me a while back??? Really appreciate it!
Re: Tires size and Gear ratio 8th mile [Re: Labratt] #864294
11/27/10 05:14 PM
11/27/10 05:14 PM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
JnkGal...You still out there???
Re: Tires size and Gear ratio 8th mile [Re: jnkgal] #864295
11/27/10 05:22 PM
11/27/10 05:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Just replace the tires UNLESS your over reving it on
the big end... what rpm do you cross the line at...
if its in the ball park save your money... I dont change
anything between racing 1/4 or 1/8... its bracket racing
Re: Tires size and Gear ratio 8th mile [Re: Labratt] #864296
11/27/10 09:11 PM
11/27/10 09:11 PM
Daisyland USA
jnkgal Offline OP
jnkgal  Offline OP
Daisyland USA
yep still here. I cant stay on here much since I got into the program which I hope to graduate in may. Between studying and playing with cars etc I dont have much free time
we are preparing to race this next season. We hope to take two so we can race each other.
Last year the Satellite crossed the line 7.38 6300RPM with a 440 and same set up. Was thinking with the 540 and more torque may need less gear or smaller tire
Im posting a video I have to laugh it was the first video I ever took with this new camera sooo... I got a lot of ground lol I was looking around too much & learning how to adjust this camera at the same time so the video suffered.. I am good with video now this video was taken 2008
the camaro that was beat was a car my freind " the camaro guy" sold to this guy.
Mopar Burnout 2008
Re: Tires size and Gear ratio 8th mile [Re: jnkgal] #864297
11/27/10 09:50 PM
11/27/10 09:50 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Things got enough torque to pull fire hydrants outta the ground. I would think 4.10-4.30 as is in the vid. And roll through the water before burnout..slings water up only to fall back on the tires. Driving around the water is a good idea too.
Yeah, it's got a smallblock.
Re: Tires size and Gear ratio 8th mile [Re: jnkgal] #864298
11/27/10 09:54 PM
11/27/10 09:54 PM
Daisyland USA
jnkgal Offline OP
jnkgal  Offline OP
Daisyland USA
here is a better video
Nashville Super Speedway Friday Nite drags
and this one where I am hesitant to post cause the sound is bad. This is a sony camera this time and it does great picts and video but sound is not so good. This car sounds awesome in person!
This is us riding together on Co Pilot nite at union hill 2008
2008 CoPilot at union hill
Re: Tires size and Gear ratio 8th mile [Re: jnkgal] #864299
11/27/10 11:14 PM
11/27/10 11:14 PM
Daisyland USA
jnkgal Offline OP
jnkgal  Offline OP
Daisyland USA
the one video we took co pilot at union hill we had to short shift to stay under 850 or get kicked out of that class
Re: Tires size and Gear ratio 8th mile [Re: 340B5] #864300
11/27/10 11:19 PM
11/27/10 11:19 PM
Daisyland USA
jnkgal Offline OP
jnkgal  Offline OP
Daisyland USA
that was the "old" 440 motor
we have refreshed since then lol
its now a 540
lol yea we will have to try that sometime ..there is a fire hydrant close to the front yard
Re: Tires size and Gear ratio 8th mile [Re: jnkgal] #864301
11/27/10 11:56 PM
11/27/10 11:56 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
id kep the 4.56 and go with 30 inch slicks, unless you out of motor at 1/4
MOPAR OR NO CAR
