Any 440 block or crank failures with boost?
#864052
11/26/10 03:37 PM
11/26/10 03:37 PM
Posts: 28,069 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I was wondering if anyone has experienced a stock block or crank failure on a blown/turbo 440? I'm not talking about rods cutting loose and turning other parts into scrap metal. I know that happens.
Mine was always a mild setup and I never had any concerns with parts failures. What about you guys making just a wee bit more power?
Re: Any 440 block or crank failures with boost?
[Re: feets]
#864053
11/26/10 08:02 PM
11/26/10 08:02 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
My experience indicates the weakest link in my combo(400 block, factory 440 crank stroked to 3.90, turned down mains)was the cylinder bores. I had no filler in the water jackets, and my bores always measured out to be barrel shaped. The one thing I would suggest to anyone building a more serious big block, would be to eliminate the R/L head feed from the cam bearing. The factory setup is bad enough, but it's compounded by cam manufacturers that decide to grove the cam to feed the heads full time(stealing oil pressure from #4 main and #6 rod.)
[Re: TRENDZ]
#864054
11/27/10 01:08 AM
11/27/10 01:08 AM
feets
Senior Management
Senior Management
Irving, TX
I expected the walls to be more of a point of failure than the bottom end. Things are pretty beefy down there but detonation can break anything.
[Re: TRENDZ]
#864055
11/27/10 11:09 PM
11/27/10 11:09 PM
Posts: 66 Reno, NV
Wilde Racing
Reno, NV
Can you explain this a bit more to someone whom is a chevy guy and has VERY little knowledge of the oil route of the 440 block.....
[Re: Wilde Racing]
#864056
11/28/10 12:06 AM
11/28/10 12:06 AM
TRENDZ
Milwaukee WI
These engines feed oil to the mains, rods, and cam bearings through the main galley.(pass side of block) There is a drilling from each main saddle into the main galley to feed the crank and cam bearings. The #4 main feeds the crank, 2 rods, the cam bearing, and both cylinder heads rocker gear. On a factory setup the cam bearing is not grooved, but has three holes to feed oil to the heads. The oil in this setup is only transmitted to the heads when the drillings in the camshaft are in time with the holes in the #4 cam bearing. This is great for the lower end, but limits oiling needed on a race valve trane. The "solution" comes in a few forms. The cam bearings are available with a groove, and camshafts come with #4 journal grooved. Both are bad solutions in my opinion, but when both are done, can be devestating to the oil supply to the lower end. What I do, is install that cam bearing rotated so only the main to cam feed is open(blocking the drillings up to the heads) This oils only the cam bearing like all the others. Then from the valley area of the block, I drill through the head feed drilling- right into the main galley on both sides of the block. I cap the drilling with a 1/16" pipe plug. This supplies the heads with all the oil they need without starving a section of the lower end.
[Re: TRENDZ]
#864057
11/28/10 12:22 PM
11/28/10 12:22 PM
Posts: 121 mid-mich
turboplymouth
mid-mich
So the galley on the side of the lifters now feeds the heads. Am I reading that right?
'72 Scamp, 3500#, 440, S400, blowthrough, meth. inj.
9.78 @ 139 so far at 12 psi, 11.00 @ 131 on real street tires.
[Re: turboplymouth]
#864058
11/28/10 09:21 PM
11/28/10 09:21 PM
TRENDZ
Milwaukee WI
Correct. you must do this to both sides.
[Re: Defbob]
#864061
12/01/10 01:39 PM
12/01/10 01:39 PM
Posts: 2,260 IL
furious70
IL
Interesting, same day over on the C body dry dock an ex-police/fleet mechanic said they used to do the same thing to cruiser BB's to keep the oil where they needed it for sustained pursuit speeds.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: jrmopar1]
#864064
04/18/11 12:02 PM
04/18/11 12:02 PM
TRENDZ
Milwaukee WI
The hole you drill through to the main galley is your restrictor... I drilled mine with a 1/8" bit. I suppose you could drill it any size you feel is needed. The tricky part is drilling and tapping the 1/16" pipe thread. Restrictors are not usually installed to help the valve trane, they are installed to help the bottom end live. Alot of high end engines have EXTRA oiling to the top end to keep things up there happy.
[Re: Wilde Racing]
#864066
04/22/11 06:16 PM
04/22/11 06:16 PM
TRENDZ
Milwaukee WI
32-36 psi hot @800rpm with 20-50 synthetic. This is with the milodon twin inlet long pump.
[Re: TRENDZ]
#864068
06/15/11 08:52 PM
06/15/11 08:52 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
"" What I do, is install that cam bearing rotated so only the main to cam feed is open(blocking the drillings up to the heads) This oils only the cam bearing like all the others.""
Im doing this mod right now, and found out that there is no way you can turn or flip that bearing to cut off the oil supply to the heads and just isolate the lube to the cam as stated. The bearings holes will still line up with either one side or the other.
To do that a seperate hole must be drilled.
Trendz, you must still have one bank assist feeding the heads. That should be okay as the oil will follow the path of least resistance and most of the flow if not all of it is still coming from the oil galley mod. mike
[Re: Sport440]
#864069
06/15/11 11:22 PM
06/15/11 11:22 PM
TRENDZ
Milwaukee WI
Yeah forgot to mention that. The bearing in mine is turned and drilled. It's been awhile, but I think you can swap bearings with one of the others. If I remember correctly, there are 3 different sized cam bearings, and the two centers can be exchanged if you do this. I could be wrong though...
[Re: TRENDZ]
#864070
06/15/11 11:39 PM
06/15/11 11:39 PM
Sport440
Canton, Ohio
Just checked, they are all different diameters. I ended up drilling mine though too.
My Hats off to you for the idea and info!
IMO, this should be a standard upgrade to any race block.
