What do you guys "FOG" your motor with ?
#863336
11/25/10 08:40 AM
11/25/10 08:40 AM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
winterizing the race car,,,,have it on jack stands,,put some anti-freeze in it ( although it doesnt get too cold here )
I had a name of some stuff to use,,,and cant find where i wrote it down,,,motor magic ?,,miracle motor ,, ?????
what do you guys use ?
something i can find at the local NAPA,,,autozone,,etc ?
Doug
Re: What do you guys "FOG" your motor with ?
[Re: 69CHARGERMD]
#863338
11/25/10 08:58 AM
11/25/10 08:58 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Doug I just use WD-40... I buy it in the gallon can and run the engine and pour it slowly down the carb till it stalls(with the fuel pump off and wait till its starting to run out of fuel)... now with the E-85 I am pumping it into the carb also
[Re: MegaDart]
#863341
11/25/10 11:16 AM
11/25/10 11:16 AM
69CHARGERMD
KENTUCKY
Thanks guys,,,i couldnt remember the name,,,,,hope they have it at the local auto store.........
Mike,,,you "kill" it (FOG it) with the fuel pump off ?,,, ( to get all the fuel out of the carb,,? )
[Re: 69CHARGERMD]
#863342
11/25/10 11:22 AM
11/25/10 11:22 AM
MR_P_BODY
Yes... I fill the bowls then turn off the pump fire it up and when it starts to hesitate when pumping it I pour enough in to kill it as the fuel runs out
[Re: MR_P_BODY]
#863343
11/25/10 01:55 PM
11/25/10 01:55 PM
Posts: 644 Minnesota
Barnstorm
Minnesota
Sea foam Deep Creep works well..just make a "clean out" pass in the spring...no need to change plugs. We're not fans of WD-40 in the motor.
The little old lady from Pasadena is back!
