What do you guys "FOG" your motor with ? #863336
11/25/10 08:40 AM
11/25/10 08:40 AM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
winterizing the race car,,,,have it on jack stands,,put some anti-freeze in it ( although it doesnt get too cold here )
I had a name of some stuff to use,,,and cant find where i wrote it down,,,motor magic ?,,miracle motor ,, ?????
what do you guys use ?
something i can find at the local NAPA,,,autozone,,etc ?
Doug
Re: What do you guys "FOG" your motor with ? [Re: 69CHARGERMD] #863337
11/25/10 08:56 AM
11/25/10 08:56 AM
Mooresville, NC
A70Runner Offline
A70Runner  Offline
Mooresville, NC
Marvels Mystery oil
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: What do you guys "FOG" your motor with ? [Re: 69CHARGERMD] #863338
11/25/10 08:58 AM
11/25/10 08:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Doug I just use WD-40... I buy it in the gallon can
and run the engine and pour it slowly down the carb
till it stalls(with the fuel pump off and wait till
its starting to run out of fuel)... now with the E-85
I am pumping it into the carb also
Re: What do you guys "FOG" your motor with ? [Re: MR_P_BODY] #863339
11/25/10 09:33 AM
11/25/10 09:33 AM
gregsdart Offline
gregsdart  Offline
You can buy fogging oil in spray cans at a marine store. I use it , but i don't think the spark plugs like it. Could be wrong on the plugs though.
Re: What do you guys "FOG" your motor with ? [Re: gregsdart] #863340
11/25/10 09:58 AM
11/25/10 09:58 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
marine fogging oil here. marvel mystery oil in all pumps.
Re: What do you guys "FOG" your motor with ? [Re: MegaDart] #863341
11/25/10 11:16 AM
11/25/10 11:16 AM
KENTUCKY
KENTUCKY
Thanks guys,,,i couldnt remember the name,,,,,hope they have it at the local auto store.........
Mike,,,you "kill" it (FOG it) with the fuel pump off ?,,, ( to get all the fuel out of the carb,,? )
Re: What do you guys "FOG" your motor with ? [Re: 69CHARGERMD] #863342
11/25/10 11:22 AM
11/25/10 11:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes... I fill the bowls then turn off the pump fire
it up and when it starts to hesitate when pumping it
I pour enough in to kill it as the fuel runs out
Re: What do you guys "FOG" your motor with ? [Re: MR_P_BODY] #863343
11/25/10 01:55 PM
11/25/10 01:55 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Sea foam Deep Creep works well..just make a "clean out" pass in the spring...no need to change plugs. We're not fans of WD-40 in the motor.
The little old lady from Pasadena is back!
Re: What do you guys "FOG" your motor with ? [Re: Barnstorm] #863344
11/25/10 02:08 PM
11/25/10 02:08 PM
IN
ahy Offline
ahy  Offline
IN
At a boatyard I once worked at we used motor oil. Start engine and run at fast idle. Pour slowly at first then faster until it almost dies or does die and shut it off. Good in a damp boat shed as long as the motor isn't started during the winter.
