Re: Torque converter/ flex plate won't line up
[Re: moparx]
#863051
11/25/10 11:07 AM
11/25/10 11:07 AM
Posts: 15,487 Florida
scratchnfotraction
i have learned to test fit them before the install and mark it with a spot of paint use to be every one i did had to try it 3-4 times to get it if its comeing out for the first time i spot it with paint when i remove the first bolt on the TC/flex plate you should run a bushing in the place of a muffler bearing...i thought everyone knew that,it was an option yrs ago
[Re: Hoof Hearted]
#863055
11/25/10 06:38 PM
11/25/10 06:38 PM
scratchnfotraction
I let it lay there and cool off some pick it up on the next lap around after its thined the pack behind me some then just it back on at the pitstop for gas its allways good till it falls off agian,recycling is the way now days guys
[Re: StealthWedge67]
#863062
11/26/10 08:53 PM
11/26/10 08:53 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Come on guys, everyone knows you can eliminate your muffler bearing bushings, as long as you run HP waterjackets!
I have a set of HP waterjackets. How do I know if they are from a 6 pack?
