Torque converter/ flex plate won't line up #863045
11/24/10 11:43 PM
11/24/10 11:43 PM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
I have a B&M flex plate Summit part # BMM-10230 and the holes will not line up with my Torque converter. I tried rotating the converter and trying 2 bolts at a time but I can only get one bolt in at a time. When I have 1 bolt in the next hole is about a 1/4 inch off. Anybody ever have this problem? If so what was the solution ?
Re: Torque converter/ flex plate won't line up [Re: Boise Chall] #863046
11/24/10 11:57 PM
11/24/10 11:57 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Are you certain that you tried all 4 orientations? You probably know this, but the bolt holes are not spaced symmetrically, and the flex plate will only mate to the converter in one orientation.
Re: Torque converter/ flex plate won't line up [Re: davenc] #863047
11/25/10 12:05 AM
11/25/10 12:05 AM
Boise Idaho
Boise Idaho
I must have made a mistake while rotating it. I had another flex plate and converter here so I set the 2 together and I had to rotate it until it lined up and it did I will try again. If it works I will delete this post out of shear embarrassment.
Re: Torque converter/ flex plate won't line up [Re: Boise Chall] #863048
11/25/10 12:26 AM
11/25/10 12:26 AM
NC, USA
davenc Offline
davenc  Offline
NC, USA
I have made plenty of bone head mistakes as well. You might even consider leaving the post. I have found a wealth of information by searching the archives, and someone else is likely to find themselves in the same situation in the future.
Re: Torque converter/ flex plate won't line up [Re: Boise Chall] #863049
11/25/10 01:31 AM
11/25/10 01:31 AM
Boise Idaho
Boise Idaho
I found the problem it seems that the widget arm was improperly located on the maniform causing the A.S.H receiver to be too close to the muffler bearings. Either that or I need to learn how to count before I try rotate it for alignment next time ...... DOH !!!!!!!!
Re: Torque converter/ flex plate won't line up [Re: Boise Chall] #863050
11/25/10 10:00 AM
11/25/10 10:00 AM
moparx Offline
moparx  Offline
them muffler bearings will get ya every time. but them knuten valves....... boy are they ever brain wracking !........
Re: Torque converter/ flex plate won't line up [Re: moparx] #863051
11/25/10 11:07 AM
11/25/10 11:07 AM
scratchnfotraction Offline
i have learned to test fit them before the install and mark it with a spot of paint
use to be every one i did had to try it 3-4 times to get it
if its comeing out for the first time i spot it with paint when i remove the first bolt on the TC/flex plate
you should run a bushing in the place of a muffler bearing...i thought everyone knew that,it was an option yrs ago
Re: Torque converter/ flex plate won't line up [Re: scratchnfotraction] #863052
11/25/10 04:14 PM
11/25/10 04:14 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Me too! Nothing worse than laying on your back trying to start those little bolts only to find out you messed up the orientation. GRRRRRR!
2 Demons...no, not my kids!
Re: Torque converter/ flex plate won't line up [Re: scratchnfotraction] #863053
11/25/10 04:38 PM
11/25/10 04:38 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Come on guys, everyone knows you can eliminate your muffler bearing bushings, as long as you run HP waterjackets!
Re: Torque converter/ flex plate won't line up [Re: StealthWedge67] #863054
11/25/10 06:24 PM
11/25/10 06:24 PM
S.E. Conn
Hoof Hearted Offline
S.E. Conn
That's why I use a Left Handed bolt stretcher on the muffler's HypoDupilator valve when it gets stuck.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Torque converter/ flex plate won't line up [Re: Hoof Hearted] #863055
11/25/10 06:38 PM
11/25/10 06:38 PM
I let it lay there and cool off some
pick it up on the next lap around after its thined the pack behind me some
then just it back on at the pitstop for gas
its allways good till it falls off agian,recycling is the way now days guys
Re: Torque converter/ flex plate won't line up [Re: scratchnfotraction] #863056
11/25/10 07:30 PM
11/25/10 07:30 PM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
JB Weld.
Re: Torque converter/ flex plate won't line up [Re: ProStock1320] #863057
11/25/10 10:14 PM
11/25/10 10:14 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
I thought you had to use the Finley shoehorn tool from Harbor Freight to line those pesky bolts up to the converter...
Re: Torque converter/ flex plate won't line up [Re: 67dodge67] #863058
11/26/10 02:29 AM
11/26/10 02:29 AM
Boise Idaho
Boise Idaho
Oh come on guys I'm starting to feel like a Kid on the short bus or stubby bus. Quit picking on the retard. hhahahhahahhahah Just kidding this is some pretty funny stuff
Re: Torque converter/ flex plate won't line up [Re: Boise Chall] #863059
11/26/10 09:58 AM
11/26/10 09:58 AM
have you marked it yet with a dab of paint?????
Re: Torque converter/ flex plate won't line up [Re: Boise Chall] #863060
11/26/10 11:19 AM
11/26/10 11:19 AM
you better say mentally challenged instead of the R word, John might be awake
Re: Torque converter/ flex plate won't line up [Re: Boise Chall] #863061
11/26/10 07:36 PM
11/26/10 07:36 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
Just remember to be careful not to get any air in the overhead when you bleed the converter. Once there's air in there the whole trans has to come out to access the edsel valve. Don't even get me started on the damage you can do to the turbo encabulator on one of these cars when you go messing with the edsel valve. Big money repair there.
Luckily I have a trustworthy mechanic that explains this stuff to me before I waste money bringing it to a shady wrench.
Re: Torque converter/ flex plate won't line up [Re: StealthWedge67] #863062
11/26/10 08:53 PM
11/26/10 08:53 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I have a set of HP waterjackets. How do I know if they are from a 6 pack?
Re: Torque converter/ flex plate won't line up [Re: Commando1] #863063
11/26/10 10:02 PM
11/26/10 10:02 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have custom spray bar finnegin pins for the waterjackets .Does it matter what color paint I/you?we use????I leave the trans in for the 'verter change
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Torque converter/ flex plate won't line up [Re: hemi-itis] #863064
11/26/10 10:17 PM
11/26/10 10:17 PM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
Did anybody check the blinker fluid yet? Sorry had to get one in.
