Who makes the best rocker arms?? #862962
11/24/10 10:01 PM
11/24/10 10:01 PM
Ontario, Canada
Hyper Henry Offline OP
Ontario, Canada
Who would you recommend for rockers arms between Hardland Sharpe, RAS or T&D for a roller cammed RB drag only motor, best bang for the buck?? And where to get the best prices for them??
Derrick
Re: Who makes the best rocker arms?? [Re: Hyper Henry] #862963
11/24/10 10:14 PM
11/24/10 10:14 PM
MD
Kevins493 Offline
Kevins493  Offline
MD
I run T&D in mine...
Re: Who makes the best rocker arms?? [Re: Kevins493] #862964
11/24/10 10:20 PM
11/24/10 10:20 PM
Wisconsin
sjs64polara Offline
sjs64polara  Offline
Wisconsin
We have T&D, Very nice product
Re: Who makes the best rocker arms?? [Re: Hyper Henry] #862965
11/24/10 10:38 PM
11/24/10 10:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
T&D or Jesel... I run T&Ds on my stuff
Re: Who makes the best rocker arms?? [Re: MR_P_BODY] #862966
11/24/10 10:42 PM
11/24/10 10:42 PM
sycamore,ohio
BobsProFab Offline
BobsProFab  Offline
sycamore,ohio
i have T&D
Re: Who makes the best rocker arms?? [Re: MR_P_BODY] #862967
11/24/10 10:44 PM
11/24/10 10:44 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
T&D here set them and they stay set
Re: Who makes the best rocker arms?? [Re: Hyper Henry] #862968
11/24/10 10:44 PM
11/24/10 10:44 PM
I have all three brands in four diiferent motors, I would not use a set of ductile iron rockers with more than 600 lbs open pressure now, I have in the past As far as quality and bang for the buck, now that I have used T&D and Harland Sharps I would buy the Harland Sharp now for my personel use on most of mine and customers N/A motors on B and RB engines with the standard single stock type rocker arms being shifted at or under 8000 RPM (not the all out aftermarket race stuff like the paired T&D and Jesels systems) The exception would be on a all out high RPM motor with the best heads and rocker gear, which would be a Jesel system on the rockers
Re: Who makes the best rocker arms?? [Re: MR_P_BODY] #862969
11/24/10 10:45 PM
11/24/10 10:45 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I use the T&D's quite a bit as I do like them. Very high quality part. Don't be afraid of the Harland's either. Very nice stuff.
MB
Re: Who makes the best rocker arms?? [Re: HPMike] #862970
11/24/10 10:51 PM
11/24/10 10:51 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
T AND D's here
No spay bars , uck
Re: Who makes the best rocker arms?? [Re: bigdad] #862971
11/24/10 10:56 PM
11/24/10 10:56 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Are the T&D a full roller rocker ? Ron
Re: Who makes the best rocker arms?? [Re: HPMike] #862972
11/24/10 11:02 PM
11/24/10 11:02 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
I have a set of Harland Sharp roller rockers on an old set of Zeeker Pro Stock Heads. Lots and lots of runs on these rockers. The only problem ever had was a set of adjustors that were too hard and kept snapping off. Replaced the full set and no other problems. Harland Sharp also has great service. I bought a used set at a swap meet that looked rough. I sent them back to Harland Sharp and they rebuilt them for $65.00 and replaced all of the bearings
Old Geezer Racing
Re: Who makes the best rocker arms?? [Re: 383man] #862973
11/24/10 11:02 PM
11/24/10 11:02 PM
SW pa
goldenlancer Offline
SW pa
T&D on the victors here.
N/SS
Re: Who makes the best rocker arms?? [Re: 383man] #862974
11/24/10 11:12 PM
11/24/10 11:12 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Yes they are.
Re: Who makes the best rocker arms?? [Re: 383man] #862975
11/24/10 11:48 PM
11/24/10 11:48 PM
T&D sells two different(or more) types of rocker arm sets ups for BB Mopars, single shaft set ups for each head and paired rockers on four different shafts and stands per head. All of them I have seen of both types are full roller rockers
Re: Who makes the best rocker arms?? [Re: HPMike] #862976
11/24/10 11:56 PM
11/24/10 11:56 PM
Ontario, Canada
Ontario, Canada
Thanks for the feedback guys. I am just running CNC'd Eddy's so they will be for standard offset rockers and up to 700 lbs. max open and 7500 rpm max. Hardland's sound like good bang for the buck and I have ran them before with good luck (did have an adjusting stud crack though). If I do go T&D's can you only buy direct from them??
Derrick
Re: Who makes the best rocker arms?? [Re: Hyper Henry] #862977
11/25/10 12:03 AM
11/25/10 12:03 AM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
3 sets of t&d,s here.....bob mazolini racing has the best price too.
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Who makes the best rocker arms?? [Re: Old School] #862978
11/25/10 12:19 AM
11/25/10 12:19 AM
DANBURY CT
fury62 Offline
fury62  Offline
DANBURY CT
t&d on indy sr head got my best price at cv products no. carolina
Re: Who makes the best rocker arms?? [Re: fury62] #862979
11/25/10 01:27 AM
11/25/10 01:27 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I have owned or currently owned all the rockers mentioned above,hands down the T&Ds are the best. The Harland sharp rockers use to be a good value years ago,but are currently almost as much as a T&D,or Jesel when you buy the big offset intakes for Victors or indy heads ,and they (Harland sharp rocker)are no T&D
Re: Who makes the best rocker arms?? [Re: boatracer572] #862980
11/25/10 02:42 AM
11/25/10 02:42 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I have a set of new T&D for Indy 360-1 and a new set of BB Harland Sharps here. The only differece I can tell between the two is the Harland is orange. The quality, looks, and feel are the same....to me.
