Custom Instrument Panel #862654
11/24/10 05:10 PM
11/24/10 05:10 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Anyone has a custom instrument panel for a 66 Belvedere II. I'm installing manual gauges and a few other goodies and I need a panel that will fit that area and look good. I can do the cutouts if need be but if you do them then that's kewl too. Attached is the look I want. If you need to PM then by all means do so. I need openings for a Tach,Speedo,Oil Pressure,Volt,Temp and fuel.
Re: Custom Instrument Panel [Re: roy2345] #862655
12/11/10 04:26 PM
12/11/10 04:26 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
might want to try the question and answer forum. Will get little response on a car newer than 61 here.
