Mounting a Tuff wheel #862405
11/24/10 11:43 AM
11/24/10 11:43 AM
Minnesota
MTSI Offline OP
super street
MTSI  Offline OP
super street
Minnesota
I found a real nice original Tuff steering wheel. I want to put it in my 1971 Charger to replace the standard plastic 3-spoke.
I hear a lot about adaptors and such with the Tuff wheels. Do I need anything special to mount it on a standard console column?
Thanks Moparts
Re: Mounting a Tuff wheel [Re: MTSI] #862406
11/24/10 01:15 PM
11/24/10 01:15 PM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
Yep, you need one of these 3467186 adapters. This one is missing the horn ring but shows the correct mounting nuts.
This one has the horn ring and pigtail you need but is missing the mounting nuts.
The splines are different between the passenger car adapters and the adapters used on trucks; they are not interchangeable.
Re: Mounting a Tuff wheel [Re: charger440sixpak] #862407
11/24/10 01:47 PM
11/24/10 01:47 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
I put a car one on my '78 D150 pickup when I put a '72 E-body wheel in. Haven't tried going the other way.
Re: Mounting a Tuff wheel [Re: NicksGarage] #862408
11/24/10 05:11 PM
11/24/10 05:11 PM
SF Bay Area, CA
SF Bay Area, CA
I know a 78 Warlock adapter will not fit a 71 Charger... believe me I tried...
I wonder if the type of steering column has anything to do with the splines matching? Power vs. manual I mean...
Re: Mounting a Tuff wheel [Re: charger440sixpak] #862409
11/24/10 05:47 PM
11/24/10 05:47 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
The one I used came from a '71 Dart. It may be that you can use car ones on a truck but not the other way around. The only other one I have is from a Cordoba. I think one has a fat spline for locating.
Re: Mounting a Tuff wheel [Re: NicksGarage] #862410
11/25/10 04:19 PM
11/25/10 04:19 PM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Sounds like this can be a tuff job...
2 Demons...no, not my kids!
Re: Mounting a Tuff wheel [Re: charger440sixpak] #862411
11/26/10 03:21 PM
11/26/10 03:21 PM
Minnesota
MTSI Offline OP
super street
MTSI  Offline OP
super street
Minnesota
Thanks. Then I have everything I need. Just gotta pull the old one.
Re: Mounting a Tuff wheel [Re: MTSI] #862412
11/26/10 08:02 PM
11/26/10 08:02 PM
Locomotion Offline
Locomotion  Offline
Will the ribbed adapter/extension from a Challenger column adapt an aftermarket Tuff wheel to an A-body steering assembly?
Re: Mounting a Tuff wheel [Re: Locomotion] #862413
11/26/10 09:57 PM
11/26/10 09:57 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
That adapter is a lot longer than an a-body one so it will put the steering wheel a lot closer to you.
Re: Mounting a Tuff wheel [Re: charger440sixpak] #862414
11/27/10 03:03 AM
11/27/10 03:03 AM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
hhmm ive switched mine from a lil red to my challenger toa dart no issues
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: Mounting a Tuff wheel [Re: azmopar] #862415
11/28/10 01:09 PM
11/28/10 01:09 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Depends if it is was a tilt column or not. Tilt column adapters for tuff wheels won't work on E-body columns.
Re: Mounting a Tuff wheel [Re: Devil] #862416
11/28/10 01:56 PM
11/28/10 01:56 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Tilt column adapters are very rare and would only work on a tilt column. I've been looking for one for years.
Re: Mounting a Tuff wheel [Re: 4speeds4me] #862417
11/28/10 02:38 PM
11/28/10 02:38 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Mounting a Tuff wheel [Re: NicksGarage] #862418
11/28/10 04:29 PM
11/28/10 04:29 PM
SF Bay Area, CA
SF Bay Area, CA
The 70-71 & 72 parts manuals only show the 3467186 spacer (adapter) and the three 6029392 mounting nuts. Just curious how/where you found information on the tilt adapter.
Maybe mine is the tilt adapter; that would make it worth... what $2000 or $2500...
Re: Mounting a Tuff wheel [Re: charger440sixpak] #862419
11/28/10 08:42 PM
11/28/10 08:42 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
It wouldn't have come on a '71-72 tilt wheel. Probably a later truck or a car like the Magnum. All I have is this one single picture. Supposedly this is about 1 inch thick.
