Re: 64 273 question [Re: 68cuda360] #862297
04/26/11 11:25 AM
04/26/11 11:25 AM
scratchnfotraction Offline
Re: 64 273 question [Re: dart4forte] #862298
04/26/11 10:19 PM
04/26/11 10:19 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
I was pretty sure I had a 67 with hydro non adjust rockers
might have been worked on before I gots it
what are the specs on that E4 grind?
uncle had a 273 with a .500 lift something or other that was nasty in the 273,he siad 273 hipo but I thinks it was aftermarket with that lift
I know they can be fast..just ask member "Class of 65" with a record holder 273
There was a 273 Super command i think they called it from the factory .500 lift solid cam and a 750 holley very rare however
You must be referring to the D/Dart
Yep-per!! They took the 10.5 cr, 235 hp/273 motor
and just gave it a DEEP breathing exercise. Chrysler changed the 235hp solid cam to the 275hp
solid cam (284-284/60 ovlp/.505in - .505ex) with matching springs. Good
cam for the 273, as stated before, gotta keep the
rpm's up in the midrange or above to make power. They also replaced the 500cfm Carter AFB, with the 700-750 Holley carb. Good package!!
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 64 273 question [Re: scratchnfotraction] #862299
04/27/11 01:33 AM
04/27/11 01:33 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
IIRC 67 273 is non adjustable rockers and hydro lifters
the 64 is solid lifter cup and ball push rods adjustable rockers
could have a steel crank in both
64 may have closed chamberd heads with small valves
I think 65 is the oddball intake bolt pattern on the 273..1 yr only
67 was solid lifters. Changed to hydro in 68
Re: 64 273 question [Re: Jim_Lusk] #862300
04/27/11 01:34 AM
04/27/11 01:34 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Also, use the 67 heads so that you have more intake choices, unless you already have the intake you want to run with the early heads.
Also the 920's flow better
Re: 64 273 question [Re: 68cuda360] #862301
04/27/11 01:37 AM
04/27/11 01:37 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Hey Jim, I didn't see you at SpringFling.
Re: 64 273 question [Re: dart4forte] #862302
04/27/11 01:58 AM
04/27/11 01:58 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I was there, but I didn't have a swap space or a car in the show so I was mostly wandering. I did get a few good buys in the swap, though.
Re: 64 273 question [Re: Jim_Lusk] #862303
04/27/11 02:17 AM
04/27/11 02:17 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Yeah, I scored a set of 273 valve covers for $60
Re: 64 273 question [Re: dart4forte] #862304
04/27/11 02:39 AM
04/27/11 02:39 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I think you walked right by me with them. I heard somebody saying something and looked at the covers, but not the guy carrying them......
Re: 64 273 question [Re: Jim_Lusk] #862305
04/27/11 01:29 PM
04/27/11 01:29 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Guy wanted $90, I offered $60. SOLD!!!!
