64 273 question #862277
11/24/10 02:34 AM
11/24/10 02:34 AM
Metro Detroit area / Warren
68cuda360 Offline OP
I have a stock '64 273 engine, minus the rockers, shafts & pushrods. Can I use those items from a 1981 318 ??
Re: 64 273 question [Re: 68cuda360] #862278
11/24/10 03:53 AM
11/24/10 03:53 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
If my memory is correct, the 64 273 has solid lifters. This requires adjustable valvetrain, which is now missing, right?
My guess is that you can use the 318 stuff as long as you change to a new hydraulic cam and lifters. That would probably be cheaper than to try to find the stock adjustable stuff for a fair price.
Re: 64 273 question [Re: 68cuda360] #862279
11/24/10 08:35 AM
11/24/10 08:35 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I did a '65 273 by changing to a Comp hydraulic cam and kit and using later 318 LA pushrods, and rocker setup. Works just fine.
This is the land of the free because of the brave
Re: 64 273 question [Re: 68cuda360] #862280
11/24/10 09:43 AM
11/24/10 09:43 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Or you can likely get a good running 318 for free here just for the asking, have 45 more cubes and no one`will be the wiser.
Re: 64 273 question [Re: jcc] #862281
11/24/10 10:28 PM
11/24/10 10:28 PM
thanks for the replies. I bought a complete '67 273 locally today for $150. I'll take the rocker assy stuff & part out what I can with the rest of the engine.
Re: 64 273 question [Re: 68cuda360] #862282
11/24/10 10:36 PM
11/24/10 10:36 PM
scratchnfotraction Offline
IIRC 67 273 is non adjustable rockers and hydro lifters
the 64 is solid lifter cup and ball push rods adjustable rockers
could have a steel crank in both
64 may have closed chamberd heads with small valves
I think 65 is the oddball intake bolt pattern on the 273..1 yr only
Re: 64 273 question [Re: scratchnfotraction] #862283
11/24/10 10:51 PM
11/24/10 10:51 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Both '64 and '65 have the oddball intake/head setup. The 273 was introduced partway through '64.
Re: 64 273 question [Re: NicksGarage] #862284
11/24/10 10:55 PM
11/24/10 10:55 PM
my bad
I would love to get the HIPO solid cam/PR/rockers myself for a 318
made a nice peppy 318 last time
Re: 64 273 question [Re: scratchnfotraction] #862285
11/24/10 11:03 PM
11/24/10 11:03 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
ALL 273s had solid lifters through 1967. Hydraulics for 68 and 69.
Re: 64 273 question [Re: Jim_Lusk] #862286
11/24/10 11:04 PM
11/24/10 11:04 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Also, use the 67 heads so that you have more intake choices, unless you already have the intake you want to run with the early heads.
Re: 64 273 question [Re: Jim_Lusk] #862287
11/24/10 11:18 PM
11/24/10 11:18 PM
Have intake and carb from '64 engine & actually had the engine running ,just not very good. Way too much slop in the rockers.
So gonna just change to adjustable & keep going. Thanks guys.
Re: 64 273 question [Re: 68cuda360] #862288
11/24/10 11:49 PM
11/24/10 11:49 PM
Roseville
FuryousOne Offline
FuryousOne  Offline
Roseville
How about putting in a flathead 6...I know where you can get a couple really cheap
Re: 64 273 question [Re: scratchnfotraction] #862289
11/25/10 03:07 AM
11/25/10 03:07 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
67 was still solid. 273 went to hyd cam starting in 68. Also, the Isky E4 is a good grind for the 273.
Re: 64 273 question [Re: dart4forte] #862290
11/25/10 11:16 AM
11/25/10 11:16 AM
I was pretty sure I had a 67 with hydro non adjust rockers
might have been worked on before I gots it
what are the specs on that E4 grind?
uncle had a 273 with a .500 lift something or other that was nasty in the 273,he siad 273 hipo but I thinks it was aftermarket with that lift
I know they can be fast..just ask member "Class of 65" with a record holder 273
Re: 64 273 question [Re: Jim_Lusk] #862291
11/25/10 11:17 AM
11/25/10 11:17 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Ran a Performer intake on my 65 273 with no problems. You can run a later intake on the early 273, just not the other way around.
Don't be the exception.
Re: 64 273 question [Re: scratchnfotraction] #862292
11/25/10 01:58 PM
11/25/10 01:58 PM
NY usa
540challenger Offline
NY usa
There was a 273 Super command i think they called it from the factory .500 lift solid cam and a 750 holley very rare however
Re: 64 273 question [Re: Supercuda] #862293
11/25/10 03:03 PM
11/25/10 03:03 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The performer or any other later style intake will not bolt directly onto a 65 273 head. Your heads were swapped for later heads or the bolt holes on the intake were wallowed out.
Re: 64 273 question [Re: 540challenger] #862294
11/25/10 09:30 PM
11/25/10 09:30 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
You must be referring to the D/Dart
Re: 64 273 question [Re: 68cuda360] #862295
11/25/10 09:43 PM
11/25/10 09:43 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
http://www.iskycams.com/onlinecatalog.html
Here's a good 273 combo.
Run a CR of 9.1 to 9.5
E4 Isky solid Cam
Find a set of 920 casting heads (66-67). They flow the best. They flow better running a stainless 1.88 intake valve cut down to 1.82. That way there's no shrouding. If you can't find that casting 302's are a good alternative.
Run a Edelbrock LD4B and a Carter 625. Of course a good ignition and exhaust.
273's make power as long as the RPMs are up. 273's like a lot of gear. For a street A body with a 273 3.91's are a good start.
Re: 64 273 question [Re: dart4forte] #862296
11/25/10 09:48 PM
11/25/10 09:48 PM
Good info, thanks. We are staying stock for now. Engine is in a 54 Dodge, traditional style hot rod. Just a cruiser for the old man.
