How much gain from a proper converter? #862256
11/24/10 02:23 AM
11/24/10 02:23 AM
tboomer Offline OP
tboomer  Offline OP
What is the most gain that you guys have seen from a properly speced converter for your combo? The reason I ask is that we may be going on strike at the end of Dec. at work... I did get the ladder bar kit bought and saved enough cash up to have bad1970dust install it. I was planning on a complete tranny rebuild with a brake...But that may have to wait. There is no doubt that my current converter cannot handle the power that the 512 is putting out...Also talked with three different converter guys and got three different answers!! The cheapest way is that Kenny Ford would rebuild my current PTC that is in the car now. I have no complaints on the PTC...It did what he said behind the 446"....Give me your thoughts,guys!!
Re: How much gain from a proper converter? [Re: tboomer] #862257
11/24/10 06:01 AM
11/24/10 06:01 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
IF you are going to be out of work, you need to rethink the car thing for a while. Push it off to the side, and make sure you and your wife are taken care of first. Haven't raced mine in 3 years because of this.
You are going to gain quite a bit by doing the ladder bars first. The convertor? Hard to say. Mike's picked up around a 1/10th, but the consistancy picked up a bunch. Faster you go the harder gains become.
Re: How much gain from a proper converter? [Re: tboomer] #862258
11/24/10 07:23 AM
11/24/10 07:23 AM
Q
Quicktree Offline
Quicktree  Offline
Q
depends on what size you are running now and how far it's out.
Re: How much gain from a proper converter? [Re: Quicktree] #862259
11/24/10 08:13 AM
11/24/10 08:13 AM
pa
572charger Offline
572charger  Offline
pa
ck your convertor slip on wallace racing calculator wifes car had 22% slip changed convertor to one that was only 15% slip car went from 11.22 at 119 to 10.79 at 124 we are getting one made for the car should go 10.50s at 127 if we get the slip down to 7-10% like it should be
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: How much gain from a proper converter? [Re: 572charger] #862260
11/24/10 08:35 AM
11/24/10 08:35 AM
gregsdart Offline
gregsdart  Offline
Nobody can really say, unless you had a seriously tight converter to start with. Then they might get a vague idea. My personal experience has been gains are small in the tens and faster, unless the converter is seriously messed up. Main thing is it is going to be a few bucks to get one built to handle a brake and live behind a stroker. No short cuts allowed. I had a ten inch TCI I had them redo for a brake and it ate itself in short order. The insides looked like someone beat it up with a big ball peen hammer. $500 gone. So the rep of the builder is your best insurance, go with his recommendations.
Ted , you like to bracket race and win more than go after the last .01 in performance I will bet, so going on the loose side with a big motor will greatly help that. At least that is what I have seen. I went from about 5500 rpm to 6400 flash on my deal, picked up about .05 or so despite the fact that I shift at 7100 or 7200 rpm. It also is deadly consistent when I do my job.
Good luck on the job situation! Would like to come to CFR and meet in person next spring!
Re: How much gain from a proper converter? [Re: tboomer] #862261
11/24/10 10:39 AM
11/24/10 10:39 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
PTC can adjust it if you go that way.thay adjusted mine for the blower with a steel stator,balooning plate from a N/A 500hp TC.
good luck with the job and all!
Re: How much gain from a proper converter? [Re: blownzoom440] #862262
11/24/10 11:21 AM
11/24/10 11:21 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
If they don't hit the mark with the proper stall it can make a night & day difference,at least for me it has. My TCS will flash to 5400 behind my 408 and be dead on consistant.I did however lose the sprag one year and some one told me they had closed shop so i bought another TC. This converter hasn't matched it at all,1st time too tight with 4800 flash then 2nd time too loose with 6200 flash.Of course later found that TCS was still around and got it fixed
This winter the motor will get a dyno and give the converter guy the correct TQ reading.3rd times a charm right.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: How much gain from a proper converter? [Re: 77DragracerR/T] #862263
11/24/10 12:35 PM
11/24/10 12:35 PM
tboomer Offline OP
tboomer  Offline OP
Thanks for the input,guys! Strike pay don't go too far! We have enough set aside to make it thru winter if it comes to that. Greg and Jeff..would love to see you guys at CFR....and bring whats his name with the yellow Dart that has orange bumpers!!
Re: How much gain from a proper converter? [Re: 77DragracerR/T] #862264
11/24/10 12:45 PM
11/24/10 12:45 PM
Wheels up, MO
N
nhramark Offline
nhramark  Offline
N
Wheels up, MO
I would give PTC first shot at it, Kenny has always come through for me. On my 540 I went from 9.70's with an 8" converter (that I was driving through at 800 ft) to 9.40's with a 5800 stall 9 1/2" converter. I had that same 9 1/2" loosened to about 6200 and dropped down to 9.20's/9 teens with no other changes, so several tenths are possible.
I agree though, if you may go on strike, don't spend one penny on that car. Parts can always be bought later when/if things work out......
[image]http://s1126.photobucket.com/user/nhramark1/library/Racing[/image] 9.100 @ 150 mph 5.780 @ 120 mph
Re: How much gain from a proper converter? [Re: nhramark] #862265
11/24/10 12:51 PM
11/24/10 12:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
As stated already it depends on how off your current one is...
Re: How much gain from a proper converter? [Re: nhramark] #862266
11/24/10 12:52 PM
11/24/10 12:52 PM
tboomer Offline OP
tboomer  Offline OP
Thanks,Mark! The PTC is a 4200 9 1/2" unit. I did talk to Kenny and discussed it. He says he can make it work behind the 512. My job isn't bad...Just crappy hours and a hundred mile round trip a day. They sure picked a bad time of the year for contract!!
Re: How much gain from a proper converter? [Re: tboomer] #862267
11/24/10 01:01 PM
11/24/10 01:01 PM
ELYRIA,OH
ELYRIA,OH
do you have a part # off the convertor stamped on it?just wondering what it is.
Re: How much gain from a proper converter? [Re: tboomer] #862268
11/24/10 01:21 PM
11/24/10 01:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you can probably make it work, but going from what ever it ends up being I bet an 8" 5600ish/or more converter would pick you up at least a .10 or more thats providing you can make it hook. just my guess
Re: How much gain from a proper converter? [Re: blownzoom440] #862269
11/24/10 01:22 PM
11/24/10 01:22 PM
Central,Ohio
FASTFISH420 Offline
FASTFISH420  Offline
Central,Ohio
I run a 7inch from ptc and you can see 5 to 6 tenth,from what I have tried,but it depends on how far it is off..takes alot of time to get one right..mine is like 3% slippage..but I have had it adjusted 10 times or more
1969 Barracuda 8 second all/motor small block 2014 Shelby GT500 Mustang Uratchko Racing Engines www.URE-RACING.com
Re: How much gain from a proper converter? [Re: tboomer] #862270
11/24/10 02:17 PM
11/24/10 02:17 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
In my case, it was .2 and 2 MPH. As they say, "Your results may vary!"
Re: How much gain from a proper converter? [Re: BradH] #862271
11/24/10 08:03 PM
11/24/10 08:03 PM
new jersey usa
11secdart Online content
11secdart  Online Content
new jersey usa
Every application is different but years ago I broke one of my 340s and had a 318 in my car , nothing special, little cam ,360 heads, 750 dp etc with 3.91 gears it ran a best of 13.20 with a 10 inch converter. I put in a 8 inch T/A 4600 stall converter and went 12.70s.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: How much gain from a proper converter? [Re: 11secdart] #862272
11/25/10 03:24 AM
11/25/10 03:24 AM
tboomer Offline OP
tboomer  Offline OP
That there is a pretty good gain!! We got word today that the idiots are going back into negotiations next thurs. and fri...
