correct colors on the case for a 3.23 gear? #861154
11/23/10 01:16 AM
11/23/10 01:16 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
What would be the correct colors painted on a 1970 489 case with a 3.23 gear? I believe the factory used to id the gear ratios by dabbing 3 paint marks on the bottom of the case?
Re: correct colors on the case for a 3.23 gear? [Re: ccdave] #861155
11/23/10 09:06 PM
11/23/10 09:06 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
Ask and ye shall recieve... ...Here's a list from an old mopar rag....
Re: correct colors on the case for a 3.23 gear? [Re: screamindriver] #861156
11/24/10 01:20 AM
11/24/10 01:20 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Thank you
Re: correct colors on the case for a 3.23 gear? [Re: ccdave] #861157
11/24/10 03:38 PM
11/24/10 03:38 PM
Chilly Northern, Minn.
71 Charger R/T Offline
Here's a Scheduled production date Jan 29th 1971.
Re: correct colors on the case for a 3.23 gear? [Re: 71 Charger R/T] #861158
11/24/10 07:54 PM
11/24/10 07:54 PM
Harrisburg, Pa.
Harrisburg, Pa.
That's a great example !!! Ratio color code and the orange daub for a sure-grip...Thanks for sharing... .......
Re: correct colors on the case for a 3.23 gear? [Re: screamindriver] #861159
11/24/10 10:59 PM
11/24/10 10:59 PM
MI
AfterHoursResto Offline
MI
Screamindriver, Do you have the same info for a Dana 60?
Roman Sobilo
Re: correct colors on the case for a 3.23 gear? [Re: AfterHoursResto] #861160
11/24/10 11:31 PM
11/24/10 11:31 PM
Ontario, Canada
FJ5_Fish Offline
FJ5_Fish  Offline
Ontario, Canada
Dana's had a 3.54 or a 4.10 ..Noted on the metal tag..They didn't have all the war paint an 8-3/4 has (unless Dream Car Garage did the resto). The date codes (and other info - see below) are hard stamped into the axle tube.
Bill of Materials Numbers:
68-69 B body 3.54 Powr-Lok 602957-1, -2, -3, -4
4.10 Powr-Lok 602957-5, -6
69.5-70 B body 3.54 Powr-Lok 603109-1, -2
4.10 Powr-Lok 603109-3, -5
4.56 Powr-Lok 603109-6, -7, -8
70-72 B body 3.54 Trac-Lok 603222-1, -2
4.10 Trac-Lok 603222-3
4.56 Trac-Lok 603222-4
75-77 B body 5.13 Powr-Lok 603347-2
5.38 Powr-Lok 603347-1
69-71 E body 3.54 Powr-Lok 603080-1, -2, -4
4.10 Powr-Lok 603080-3, -5
4.56 Powr-Lok 603080-6, -7
70-72 E body 3.54 Trac-Lok 603226-1, -2
4.10 Trac-Lok 603226-4
