Re: LA vs. Magnum Timing Chain
[Re: 73ChargerSE]
#861036
11/23/10 12:23 AM
11/23/10 12:23 AM
Posts: 178 Tidewater, VA
TMCCuda
Tidewater, VA
LA chain will work. I've used the Cloyes 3103 on my 94 5.2 Magnum and put a Comp 2103 on my 99 5.9.
1970 Plymouth Barracuda
1994 Ram 1500 4x4 5.2L
2004 Ram 1500 4x4 5.7L Quad Cab
[Re: 4speeds4me]
#861039
11/23/10 10:27 PM
11/23/10 10:27 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Magnum engine should already have the tensioner from the factory. But you may want to look it over and consider a new one.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#861040
11/25/10 10:43 AM
11/25/10 10:43 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Not all do and if your running a double roller I'd not bother, just extra friction.
A tip from the guys at KRC.
[Re: gdonovan]
#861041
11/25/10 11:00 AM
11/25/10 11:00 AM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
I used the cloyes on both my 2000 engines, fit just fine. Early Magnums came with the chain tensioner, later ones did not. My engine builder recommended using it on the later engines as well so I put one on.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
[Re: scratchnfotraction]
#861043
11/25/10 07:35 PM
11/25/10 07:35 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
You'll notice a big difference in the timing between the timing chain tensioner and not. With one, the timing stays steady, as viewed with a timing light.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
