Re: Weiand tunnel ram to Indy tunnel ram????
[Re: vttm]
#860639
11/22/10 03:04 PM
11/22/10 03:04 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
I would like to know also
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: vttm]
#860640
11/22/10 04:25 PM
11/22/10 04:25 PM
Posts: 1,361 Wild West
M_D
Wild West
Way back when I couldn't get any large port tunnel rams I enlarged the runners on a standard tunnel ram all the way through to the plenum. The runners were significantly enlarged in cross section (~20-25%), and the car gained a couple of tenth's. Much of the original metal along the whole length of the top and even sides of the runners was gone and broke through. I believe a manifold with larger runners would probably give you another 20-30 hp, but I'm not sure offhand if the Indy might be a bit too large or not ( I don't know what the cross section of it is.) Raising the CR another 1.5-2 points would help to make use of the larger runners as well.
[Re: M_D]
#860641
11/22/10 05:47 PM
11/22/10 05:47 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
unless you add a spacer on at least one inch the Indy for a Hemi has much too small of a plenum. I have seen as much as 40 HP increase using one.When I added it over my ported Weiand there was little if any gain that I can remember
home of the Sox and Martin Hemi Duster
[Re: HEMIFRED]
#860642
11/22/10 06:15 PM
11/22/10 06:15 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
HEMIFRED, Does the Indy tunnel ram intake for the wedge need the spacer as well? I'm running 2 Terminators (2950 cfm) on it.Thanks
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#860643
11/23/10 09:21 AM
11/23/10 09:21 AM
Posts: 188 MD.
vttm
MD.
[Re: vttm]
#860647
11/23/10 06:20 PM
11/23/10 06:20 PM
Posts: 855 Brisbane Australia
572B1
Brisbane Australia
Engine has not been dynoed but best guess is 600.
My brother has a weiand ram with 750 dps and makes 600 hp. std stroke 440,edelbrock heads solid cam, pump fuel engine. 10.7 @ 125.5 in a 3700 lb street car. His ram has been port matched and a light clean up.
