Page 7 of 26 1 2 5 6 7 8 9 25 26
Re: 71 cuda pro touring project [Re: johnscudashop] #859954
07/12/11 01:07 PM
07/12/11 01:07 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Sweet! The motor is going in
Re: 71 cuda pro touring project [Re: MuuMuu101] #859955
07/13/11 03:20 PM
07/13/11 03:20 PM
san diego
JonsGottaDusta Offline
san diego
Great looking project. Going to be doing the T-56 swap into my Duster this autumn.
Re: 71 cuda pro touring project [Re: JonsGottaDusta] #859956
07/13/11 08:05 PM
07/13/11 08:05 PM
Mrytle Beach SC
johnscudashop Offline OP
Mrytle Beach SC
With all the work I have been doing lately I was finally able to set the motor into the car. I unbolted the RMS suspension and bolted the engine to it , After that I lowered the body over the motor. Other than some clearancing around the belhousing the swap went smoothly.
Re: 71 cuda pro touring project [Re: johnscudashop] #859957
07/13/11 08:06 PM
07/13/11 08:06 PM
Mrytle Beach SC
Mrytle Beach SC
Motor and trans ready to go in
Re: 71 cuda pro touring project [Re: johnscudashop] #859958
07/13/11 08:08 PM
07/13/11 08:08 PM
Mrytle Beach SC
Mrytle Beach SC
Motor installed
Re: 71 cuda pro touring project [Re: johnscudashop] #859959
07/13/11 08:10 PM
07/13/11 08:10 PM
Mrytle Beach SC
Mrytle Beach SC
bottom picture
Re: 71 cuda pro touring project [Re: johnscudashop] #859960
07/13/11 08:13 PM
07/13/11 08:13 PM
Mrytle Beach SC
Mrytle Beach SC
transmission bottom picture
Re: 71 cuda pro touring project [Re: johnscudashop] #859961
07/13/11 10:33 PM
07/13/11 10:33 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
NICE!!!
Re: 71 cuda pro touring project [Re: MuuMuu101] #859962
07/14/11 09:01 AM
07/14/11 09:01 AM
Mrytle Beach SC
Mrytle Beach SC
Another shot
Re: 71 cuda pro touring project [Re: johnscudashop] #859963
07/17/11 06:25 PM
07/17/11 06:25 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
John,
All I can say is an AWESOME build! Keep up the good work... Thanks for sharing the build and pics! You guys just amaze me.
Ray
Re: 71 cuda pro touring project [Re: johnscudashop] #859964
07/20/11 08:05 PM
07/20/11 08:05 PM
Mrytle Beach SC
Mrytle Beach SC
I got into installing the starter today. I will be using Mopar part # P5249644AB , I found that this is the only starter that will work for the Gen 3 hemi with TTI headers and the Alterkation front end. First thing I had to do is grind off 2 of the rear bolt bosses on the oil pan rail to gain clearance, (since I don't need these any way)then the starter bolts on easy.As you can see in the first picture the starter won't bolt on with the bosses on the oil pan rail in the way.
Re: 71 cuda pro touring project [Re: johnscudashop] #859965
07/20/11 08:06 PM
07/20/11 08:06 PM
Mrytle Beach SC
Mrytle Beach SC
Bosses ground down
Re: 71 cuda pro touring project [Re: johnscudashop] #859966
07/20/11 08:08 PM
07/20/11 08:08 PM
Mrytle Beach SC
Mrytle Beach SC
I had to open up the top hole for the stud on the belhousing to slip though.
Re: 71 cuda pro touring project [Re: johnscudashop] #859967
07/20/11 08:09 PM
07/20/11 08:09 PM
Mrytle Beach SC
Mrytle Beach SC
Starter installed .
Re: 71 cuda pro touring project [Re: johnscudashop] #859968
07/28/11 03:11 PM
07/28/11 03:11 PM
Mrytle Beach SC
Mrytle Beach SC
After measuring my Driveline angle at 1 degree down, I modified the transmission crossmember. The transmission has a 4 degree slant on the mounting pad so I made a Aluminum block to fit between the mount and the transmission pad with the 4 degree angle milled in. The modified transmission mount was reinforced with 1/8 plate an added to the width for more mounting area.(As you can see in the picture the 4 degree difference the T56 has with the crossmember.)
Re: 71 cuda pro touring project [Re: johnscudashop] #859969
07/28/11 03:13 PM
07/28/11 03:13 PM
Mrytle Beach SC
Mrytle Beach SC
Reinforced with 1/8 plate
Re: 71 cuda pro touring project [Re: johnscudashop] #859970
07/28/11 03:15 PM
07/28/11 03:15 PM
Mrytle Beach SC
Mrytle Beach SC
Started with a 1 1/2 X 2 block of 6061 solid aluminum
Re: 71 cuda pro touring project [Re: johnscudashop] #859971
07/28/11 03:15 PM
07/28/11 03:15 PM
Mrytle Beach SC
Mrytle Beach SC
I milled the mount surface 4 degrees
Re: 71 cuda pro touring project [Re: johnscudashop] #859972
07/28/11 03:16 PM
07/28/11 03:16 PM
Mrytle Beach SC
Mrytle Beach SC
Finished and ready to install
Re: 71 cuda pro touring project [Re: johnscudashop] #859973
07/28/11 03:17 PM
07/28/11 03:17 PM
Mrytle Beach SC
Mrytle Beach SC
Mounted in place , Don't shoot me , I havent ground down the welds on the crossmember.
