Page 6 of 26 1 2 4 5 6 7 8 25 26
Re: 71 cuda pro touring project [Re: johnscudashop] #859934
06/16/11 07:56 PM
06/16/11 07:56 PM
Mrytle Beach SC
johnscudashop Offline OP
Mrytle Beach SC
finshed ready for the blaster and epoxy
Re: 71 cuda pro touring project [Re: johnscudashop] #859935
06/22/11 05:31 PM
06/22/11 05:31 PM
Mrytle Beach SC
Mrytle Beach SC
I spent the day drilling out the spot welds and removing the Passenger side front floor pan, There was some major pin holes and felt now was the time for removal. I plan on leaving this out while I install the engine and trans as I can weld the supports easier.
Re: 71 cuda pro touring project [Re: johnscudashop] #859936
06/22/11 05:32 PM
06/22/11 05:32 PM
Mrytle Beach SC
Mrytle Beach SC
Pan removed
Re: 71 cuda pro touring project [Re: johnscudashop] #859937
06/28/11 07:28 PM
06/28/11 07:28 PM
Mrytle Beach SC
Mrytle Beach SC
After swaping to a truck rear sump oil pan, I indexed the belhousing , ajusted the CSC cushion ajustment ,I installed the clutch , pressure plate ,belhousing ,CSC line and the transmission.
Re: 71 cuda pro touring project [Re: johnscudashop] #859938
06/28/11 07:29 PM
06/28/11 07:29 PM
Mrytle Beach SC
Mrytle Beach SC
LH side
Re: 71 cuda pro touring project [Re: johnscudashop] #859939
06/28/11 07:31 PM
06/28/11 07:31 PM
Mrytle Beach SC
Mrytle Beach SC
Flyweel installed
Re: 71 cuda pro touring project [Re: johnscudashop] #859940
06/28/11 07:32 PM
06/28/11 07:32 PM
Mrytle Beach SC
Mrytle Beach SC
spec clutch
Re: 71 cuda pro touring project [Re: johnscudashop] #859941
06/28/11 07:32 PM
06/28/11 07:32 PM
Mrytle Beach SC
Mrytle Beach SC
Pressure plate installed
Re: 71 cuda pro touring project [Re: johnscudashop] #859942
06/28/11 07:35 PM
06/28/11 07:35 PM
Mrytle Beach SC
Mrytle Beach SC
I have to modify the plate that adapts the belhousing to the T56 trans because there was a slight clearance issue with the upper boss.
Re: 71 cuda pro touring project [Re: johnscudashop] #859943
06/28/11 07:36 PM
06/28/11 07:36 PM
Mrytle Beach SC
Mrytle Beach SC
Belhousing installed
Re: 71 cuda pro touring project [Re: johnscudashop] #859944
07/07/11 08:48 PM
07/07/11 08:48 PM
Mrytle Beach SC
Mrytle Beach SC
today I finished fitting the rear section of the roll bar (Im waiting on a lift in the shop so I can install the motor). everything is tack welded together for now. I plan on adding 2 removable front supports and cross brace , as I want to keep the rear seat.
Re: 71 cuda pro touring project *DELETED* [Re: johnscudashop] #859945
07/07/11 08:49 PM
07/07/11 08:49 PM
Mrytle Beach SC
Mrytle Beach SC
Post deleted by johnscudashop
Re: 71 cuda pro touring project [Re: johnscudashop] #859946
07/07/11 09:32 PM
07/07/11 09:32 PM
Mrytle Beach SC
Mrytle Beach SC
front picture
Re: 71 cuda pro touring project [Re: johnscudashop] #859947
07/08/11 09:29 AM
07/08/11 09:29 AM
Mrytle Beach SC
Mrytle Beach SC
trunk mounts picture
Re: 71 cuda pro touring project [Re: johnscudashop] #859948
07/08/11 01:21 PM
07/08/11 01:21 PM
Mrytle Beach SC
Mrytle Beach SC
Picture at the front of the car
Re: 71 cuda pro touring project [Re: johnscudashop] #859949
07/08/11 06:54 PM
07/08/11 06:54 PM
QLD Australia
Keith Black® Offline
QLD Australia
looking good John
Darren Beale
Keith Black Racing Engines®
Re: 71 cuda pro touring project [Re: Keith Black®] #859950
07/10/11 05:24 PM
07/10/11 05:24 PM
Mrytle Beach SC
Mrytle Beach SC
Thanks Darren, Here is a picture of the roll bar through the rear window.
Re: 71 cuda pro touring project [Re: johnscudashop] #859951
07/10/11 11:23 PM
07/10/11 11:23 PM
Candler,NC / Myrtle Beach, SC
JDMopar Online content
JDMopar  Online Content
Looking good John. Are you going to use the stock rear seat or aftermarket? It doesn't look like a stock rear seat will fit with the way the rear bars are mounted. I was at the beach all last week, but the wife kept me too busy to sneak off and see your car!
Re: 71 cuda pro touring project [Re: JDMopar] #859952
07/11/11 04:58 PM
07/11/11 04:58 PM
Mrytle Beach SC
Mrytle Beach SC
Sorri that I missed you,I plan on modifying the back seat frame so the bars can go through the seat.
Re: 71 cuda pro touring project [Re: johnscudashop] #859953
07/12/11 07:43 AM
07/12/11 07:43 AM
Mrytle Beach SC
Mrytle Beach SC
Motor installation updates coming
