Orange peel questions/technique questions #859818
11/21/10 08:39 PM
11/21/10 08:39 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I have never used epoxy primer before and I have limited paint experience so tomorrow will be an experiment. Is orange peel typically an air pressure issue or mixture issue or both? What adjustments should be made when I encounter it? What do I start with? What is the sequence? Thanks
Gun is Devilbiss FinishLine 3 HVLP. Paint is DP90LF
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Orange peel questions/technique questions [Re: 70B5Cuda] #859819
11/21/10 09:57 PM
11/21/10 09:57 PM
NJ
rth Offline
rth  Offline
NJ
i'm not a pro painter but have some exp.i found o/p usually because to much product while spraying. gun adjustments and trial and error.start with gun manufacters air pressures and settings.also primer has to be sanded anyway. heavy primer fills imperfections.i use a section of a old hood to set adjustments on gun before going to car.
Re: Orange peel questions/technique questions [Re: rth] #859820
11/21/10 10:00 PM
11/21/10 10:00 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Googled this
Paint film having an uneven texture that resembles the skin of an orange.
CAUSE
1. Under reduction and/or air pressure too low.
2. Thinner/reducer evaporates too fast for spray conditions.
3. Excessive film thickness or piling on of heavy wet coats.
4. Improper spray gun set-up.
5. Improper painting technique.
Re: Orange peel questions/technique questions [Re: 70B5Cuda] #859821
11/21/10 10:11 PM
11/21/10 10:11 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
Make sure that you reduce the primer as the directions say. Air pressure isn't that critical with primer. I prefer a lower air pressure to keep overspray down. Your going to sand it anyway so I wouldn't be to concerned with orange peel.
Re: Orange peel questions/technique questions [Re: 70B5Cuda] #859822
11/21/10 10:15 PM
11/21/10 10:15 PM
Why are you worried about orange peel in primer?
You're going to have to scuff epoxy to get filler primer to "bite" properly followed by numerous coats and block sanding of the filler primer so it really doesn't matter?!
Re: Orange peel questions/technique questions [Re: RobX4406] #859823
11/21/10 10:49 PM
11/21/10 10:49 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
Orange peel is designed into the paint. Factory paint has orange peel in it so without it it would be almost impossible to do a paint repair and make it match. The only way minimize the orange peel is to put your last coat on heavy but you risk runs. I don't worry about orange peel I always plan on wet sanding and buffing to get the orange peel out and any other imperfections
Re: Orange peel questions/technique questions [Re: Boise Chall] #859824
11/21/10 10:58 PM
11/21/10 10:58 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I just noticed that you said primer who cares about it in the primer. Primer is kind of like a pre top coat test. FYI I tried to use the FL3 gun when I painted my last car and ended up switching back to my silver with purple Harbor freight gun I couldn't get the FL3 gun to shoot worth a crap. I use this one with very good results it shoots alot better that the FL3 in my opinion. http://www.harborfreight.com/professiona..._campaign=4710a
Re: Orange peel questions/technique questions [Re: Boise Chall] #859825
11/23/10 11:34 AM
11/23/10 11:34 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Good post I always wonder what cause orange peel.
Re: Orange peel questions/technique questions [Re: racerx] #859826
11/23/10 01:34 PM
11/23/10 01:34 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
For me, orange peel has become a useful tool in helping to know how much to wetsand before buffing. Virtually all new cars have it on their finish coats and they have for some time.
Re: Orange peel questions/technique questions [Re: jbc426] #859827
11/23/10 01:46 PM
11/23/10 01:46 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I don't paint very well at all but I know how to wet sand, use a razor blade to remove runs and I have a guy that can buff to make the car look like glass and he only charges me $100. In my opinion it's wet sanding and buffing that makes a home paint job look like a pro paint job. http://www.moparmax.com/features/featurecar/v_5-resurrection-1.html
Re: Orange peel questions/technique questions [Re: 70B5Cuda] #859828
11/23/10 07:34 PM
11/23/10 07:34 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
Just a tip. make sure the metal you apply the epoxy primer to is at least 70 deg.
any time I have had problems with epoxy primer it has been low temp. related.
This time of year a heated paint area is a must.
Re: Orange peel questions/technique questions [Re: ToddP] #859829
11/23/10 08:18 PM
11/23/10 08:18 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
If I can add a tip also..... make sure your air is warm also. I just learned this after realizing that I paint better in the summer rather than the winter even though my garage is 78 degrees in the winter while painting. my compressor sits outside and the air is cold when it hits the gun and the paint doesn't want to lay down as well. When I paint my Roadrunner I will heat/warm the air and see if I can duplicate my summer paint work. I'm not saying that the guys on Moparts are not capable of helping with paint problems but this is a forum full of guys that paint for a living and are more than willing to help and it's how I learned. http://www.autobody101.com/forums/viewforum.php?f=5
