Re: Question - Leak Down and rings
[Re: 440Jim]
#859375
11/21/10 02:16 PM
11/21/10 02:16 PM
Posts: 2,498 PA
moparacer
PA
5-8 percent cold?
Nothing wrong with it imo.
Mines worse then that hot lol.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: 440Jim]
#859376
11/21/10 02:25 PM
11/21/10 02:25 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
all under 10%. not unless otherwise you have been seeing power fall off. in some motors leakage tests can be misleading. I had a Hemi with dykes rings that showed over 15% some at 20% .it had no problems but a leakage test was still a new toy to us. we re did the rings and there was no improvement. I have always done my tests with a warmed engine my thoughts being it does change internal shapes when hot plus at times I have seen better numbers when 140 lb is used if I had tested when new at 65 then retested at that temp at a later date I would feel more confident about the numbers being accurate
home of the Sox and Martin Hemi Duster
[Re: moparacer]
#859377
11/21/10 02:26 PM
11/21/10 02:26 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
I agree..Those numbers cold show no real issues. Then again if it is out and you have the stuff why not.
[Re: 440Jim]
#859380
11/21/10 03:13 PM
11/21/10 03:13 PM
Posts: 43,159 Bend,OR USA
Cab_Burge
I take it that your using a single gauge tester, try rocking the pistosn 2 to 4 degrees either side of TDC (carefully )with pressure and see if that helps Then add several squirts of oil into the cylinders to see if that helps, if it does I would replace the rings remember that the rings seal against the cylinder walls and the piston ring lands, both do wear Can you hear any leakage out of the valves?
[Re: Cab_Burge]
#859382
11/21/10 07:15 PM
11/21/10 07:15 PM
Posts: 16,925 NC
440Jim
NC
CAB, No. This is a Summit dual gauge leak down tester (is there another type)? I am thinking about the oil squirt method, but the raw numbers don't indicate a problem. I didn't notice any leakage out of the valves, but it would have to be pretty bad to notice that. I didn't notice any excessive blow by of oil in the header evac lines either. An oil squirt would test if the rings or the valves are leaking, but the total number seems good, so neither seems like a problem from the testing ??? The heads were touched up mid season in 2008 (new cam broke in half)
I don't have a vacuum pump. I did the initial break-in with a gas carb, and ran race gas for the first two years. Then an E85 carb the 3rd year, and injection for 2009 and 2010. This engine has 616 passes on the rings! I didn't want to say that so people wouldn't judge the condition on time, but rather condition. And the condition is pretty good? Right???
[Re: theclutcher]
#859385
11/22/10 10:37 AM
11/22/10 10:37 AM
Posts: 16,925 NC
440Jim
NC
How many passes next year? unless you want to chance re-ring mid season..... At my rate, that would last a long time.
That is a good question. History indicates I will probably put 140-150 passes on it in 2011. But I am considering running less often.
I was planning on cutting back racing in 2011 (100 passes?), and not taking the motor apart this winter. But when the oil filter gasket blew out at the finish line, that made my decision to do the tear down. I want to inspect everything, especially the bearings; and perhaps change the rod bolts, rings, etc.
[Re: Monte_Smith]
#859388
11/22/10 04:00 PM
11/22/10 04:00 PM
Posts: 16,925 NC
440Jim
NC
Monte, Thanks for the info. I do use it to check the barrel valve setting on my Ron's Flying Toilet, LOL. But that is a reference, I make final adjustments based on the wideband A/F readings at idle and staging (footbrake) with the 60ft results.
I didn't do any leak down tests since the 1st year (5 seasons now). And since the oil loss event (2 qts left in the pan, perhaps it just drained down...), I didn't want to start it for fear of hurting the crank if the bearings did take a hit.
After I take it apart, I will make the final decision, but my initial impression is that since it has 616 runs on it, and it is coming apart, I will have to take the time to have a shop hone it so the new rings seat properly. That is more a pain than the cost.
[Re: 440Jim]
#859389
11/22/10 08:46 PM
11/22/10 08:46 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
IMO, it does have some more runs left in it. But not another 650 without a reduced performance.
If its going to be taken down, I would feel Very compelled to change the rings too.
Then youd be good for another 750 runs vs another 150, IMO
But, I would be curious as to the current ring gap gain compared to the original build specs. mike
