Page 4 of 4 1 2 3 4
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859355
11/25/10 11:04 PM
11/25/10 11:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not sure what the altitude is here,but I know it's nowhere near 4000'!
Randy we are about 950' round figure... the first floor
at Chrysler (CTC) is 930'
Re: CARB CHANGE EXPECTATIONS??!!! [Re: 82ramIndy493] #859356
11/26/10 12:08 AM
11/26/10 12:08 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
GTX currently has a borrowed Bigs Holley 950HP on it! Runs Real strong with it! Unfortunately,won't be able to do any track testing until April or so! I've got a few more carbs being sent to me to try out! One 850,and a couple of ProForm 1050's...one downleg booster...the other an annular booster!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: MR_P_BODY] #859357
11/26/10 12:10 AM
11/26/10 12:10 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the info Mike! Hope ya had a GREAT Turkey Day! Warsteiner
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859358
11/26/10 12:56 AM
11/26/10 12:56 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
OK...I failed my carb measuring/recon mission today. 'Went out to the shop after work to fire up the heater and realized my power wagon was the last unit in the first bay. It dropped so much dirt and dust I was afraid to turn on the forced air heating system in fear of a dust storm. I spent the afternoon sweeping, putting patio furniture in the back room, and cleaning up from the last three rush jobs. Don't you hate it when you have to get cought up to start the next mission?
I'll pull the carb off and measure/etc hopefully Saturday.
To follow up K Falls is a tad under 4200 and it goes up up up in any direction out of the basin. Brad, we too are looking to get the hell out of here in the next six months so I can't blame your brother. The DA changes so drastically when the sun goes behind the clouds or you pass by a cold mountain run off fed lake it blows my mind. Sometimes you can actually feel the car surge a little and then the cold air comes rushing in the vents. It is really noticeable driving over the Willamette pass during early summer on a 100 degree day when you pass Odel Lake.
My theory behind using the annular was two-fold. I was hoping the better atomization of the annual booster would help make the carb more consistent performance wise (pipe dream on my part, right?) and the 1050 main body would be comparable to an 850+ cfm downleg carb. I'll say that I really love that old beater 850, it has righteous throttle response on my combo!
'Sorry about the hold up.
I'm hoping Larry with the Blue 4-speed '68 RR chimes in as he runs a QF 1050AN and could provide us with some insight.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: BradH] #859359
11/26/10 12:15 PM
11/26/10 12:15 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
... I'd have to dig 'em up, but IIRC some actual wet flow #s that BG provided when the Gold / Silver Claws came out (predecessors to the Demons) showed that the 1.56" venturi w/ annular boosters flowed no more (maybe less?) than a 1.42" venturi w/ downleg boosters...
OK, found the data I was talking about in that previous post. These are the #s that BG listed for their Gold Claw series in different venturi & booster configurations. All these are w/ 1.75" butterflies, slabbed shafts & CNC venturi inserts:
Venturi -- Booster - 1.5" Hg ==> Model
1.562 --- Annular -- 875 ==> "750"
1.425 --- Downleg -- 980 ==> "825"
1.500 --- Downleg -- 1036 ==> "975"
1.590 --- Annular -- 1017 ==> "950"
1.562 --- Downleg -- 1084 ==> "1025"
The Model designations they used at the time don't make much sense to me. The spec sheet had a footnote saying "Model sizes are based on median flow rates observed on a range of engine sizes and RPMs suited to each carburetor."
Regardless, the point I'm trying to convey is the booster configuration can have a major impact on the effective flow rate of any given venturi size.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: BradH] #859360
11/26/10 01:18 PM
11/26/10 01:18 PM
Prospect, PA
BSB67 Online content
BSB67  Online Content
Prospect, PA
....and, not all "downleg" boosters are the same either.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Jeremiah] #859361
11/26/10 05:55 PM
11/26/10 05:55 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Jeremiah...sounds like you had some fun! Sounds like a real potporri of weather out there! Today's weather here was NASTY! 28 degrees,with 30 mph wind gusts! No carb testing today,for sure! Hope you guys had a great Holiday!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859362
11/26/10 07:59 PM
11/26/10 07:59 PM
tboomer Offline
tboomer  Offline
Cold here,too,Randy...If ya was closer you could try my 1150 Dominator!!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: BradH] #859363
11/26/10 11:08 PM
11/26/10 11:08 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Excellent information sir, thank you for sharing!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Jeremiah] #859364
11/27/10 12:42 AM
11/27/10 12:42 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Brad,thanks for the info! REALLY appreciate all your help! And THANKS Teddy!...when you movin' to the Detroit area?
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859365
11/27/10 02:00 AM
11/27/10 02:00 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
Randy,I have something you should try,I took it off my car and put a M1 on with a 850 and it slowed way down. If you want to try my 6 pack let me know. Chief
Re: CARB CHANGE EXPECTATIONS??!!! [Re: pro6pakRR] #859366
11/27/10 02:49 AM
11/27/10 02:49 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the offer Chief,but I have my hands full tuning only one carb...let alone 3!!!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859367
11/27/10 03:45 AM
11/27/10 03:45 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
It's all set,ready to go.Just bolt it on and hang on. Chief
Re: CARB CHANGE EXPECTATIONS??!!! [Re: pro6pakRR] #859368
11/27/10 01:20 PM
11/27/10 01:20 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Chiefie...I might just take you up on that! Haven't played with a 6-pak set-up since 1974!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859369
11/28/10 05:49 AM
11/28/10 05:49 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
Just let me know,It's just sitting in the trailer.Doug has me talked into running a 1050 dom,on a M1 on the new engine.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: pro6pakRR] #859370
12/02/10 12:49 AM
12/02/10 12:49 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Okay...I am back with some information. I apologize for taking so darned long but winter storms have been driving lots of overtime at work.
QF Q-1050-AN OOTB Specs:
Primary Jet : 84
Secondary Jet : 90
IAB's : 73
HSB's : 33
Primary Squirter : 31
Secondary Squirter : 35
Needle & Seat : .130's
Primary PV : 4.5
Secondary PV : blocked
For comparison, here are the specs from the down-leg booster 1050:
Primary Jet Size 86
Primary Power Valve (Hg) 4.5 Hg
Secondary Jet Size 93
Primary Outer Air Bleed 70
Primary Inner Air Bleed 28
Secondary Power Valve Plug
Secondary Outer Air Bleed Sizes 70
Secondary Inner Air Bleed Sizes 28
I was surprised by the differences and wish I could make more sense of them.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859371
12/02/10 12:53 AM
12/02/10 12:53 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
I wish I had some friends that would lend me some carbs like you!!! Ok,I just wish I had friends!!! LOL
Re: CARB CHANGE EXPECTATIONS??!!! [Re: MIKES_DUSTER] #859372
12/02/10 01:16 AM
12/02/10 01:16 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Jeremiah! Good to know the baseline set-up! I'll probably have to change the squirters! The 950 has a 37pri. and a 40sec. Won't really know until I try it out! Mike..it REALLY took me by surprise how many GRACIOUS and TRUSTING people are members here! I have personally only met 2 of the 6 loaners! THANK YOU ALL for your HELP...You guys make me VERY PROUD to belong to such a Mopar Brotherhood!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859373
12/02/10 01:32 AM
12/02/10 01:32 AM
Page 4 of 4 1 2 3 4
