Page 1 of 4 1 2 3 4
CARB CHANGE EXPECTATIONS??!!! #859295
11/21/10 02:05 PM
11/21/10 02:05 PM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Would it be realistic to expect a 2-3 mph pick-up switching to a 950..or 1000HP Holley,over the 850 Holley(with air horn removed)My previous best was a 119.6 mph. Thanks in advance for your opinions! RandyB
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859296
11/21/10 02:19 PM
11/21/10 02:19 PM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Well, that would depend. If you can borrow a carb, you absolutely should try more CFM. As for buying carbs to test, not unless you're made of money.
My 500" wedge gained just over 1 mph in the 1/8 going from a 950 to a 1050 Dominator. I don't remember exactly what my gain was when I went from an 850 to the 950. But it seems like a mile an hour or so.
How big a carb, type of spacer (if any), type of boosters, etc. are best determined through testing.
Master, again and still
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859297
11/21/10 02:23 PM
11/21/10 02:23 PM
Locomotion Offline
Locomotion  Offline
It's been a while, but it seems like when I switched from a 650 double pumper to a 750 DP, I gained .10-.15, which may have been 1-1.5 mph. The 650 DP ran about the same as a 750 vacuum secondary carb. (This was on a 360.) Just my opinion, but unless the engine really needs the air flow or the tune-up is better on the bigger carb, I doubt you'll pick up 2-3 mph.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859298
11/21/10 02:33 PM
11/21/10 02:33 PM
AndyF Offline
AndyF  Offline
A 950HP is smaller than an 850 DP. The 1000HP is basically the same carb as a 850 DP. So I'd say that you wouldn't see much difference at all between those carbs unless one of them wasn't set up correctly.
The 950HP is probably the best carb to run on the street but it might slow you down just a tad at the drags. Typically the 950HP will run better than a 850 DP on the street unless you have more than 500 ci.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859299
11/21/10 02:33 PM
11/21/10 02:33 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Sorry, this is not about the carb question, but is that teflon tape on your flared fittings or anti-seize? If it is teflon tape...get that junk off there because it does absolutely nothing to seal up JIC fittings.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859300
11/21/10 03:18 PM
11/21/10 03:18 PM
Go test them and find out , it looks like you have the 950 HP and we know you have the 850 Inquiring minds want to know
Re: CARB CHANGE EXPECTATIONS??!!! [Re: AndyF] #859301
11/21/10 03:31 PM
11/21/10 03:31 PM
ohio
all spooled up Offline
ohio
ANDY can you tell us how the 950 is differed than the 850 it flows less
Re: CARB CHANGE EXPECTATIONS??!!! [Re: all spooled up] #859302
11/21/10 03:49 PM
11/21/10 03:49 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Hookd..I believe because the 950 has an 850 base and a 750 main body! Never knew the 1000 only flows as much as the 850! Cab..I really can't test the carbs out at the track until next spring..when my neck has more time to heal from the surgery! If time's an issue,I can send the 850 back this week. If not,I'd like to test it out in the spring! Please let me know! The engine seems VERY responsive with the "borrowed" 950HP installed! Still waiting for some 50*+ weather to change the air bleeds(lean out)and take it down the road! I live out in the country..2-lane blacktop road,and can get er' rolling pretty good!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: all spooled up] #859303
11/21/10 03:57 PM
11/21/10 03:57 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Quoted from Captain Budget:
A Holley "950 HP" is basically a streamlined 750-size (1.38" venturi) main body w/ an 850 (1.75") baseplate. IIRC, that's worth 820-840 cfm from what those who have flow-tested them have said.
A Holley "1000 HP" is a streamlined 850-size (1.56" venturi) main body w/ a 1.75" baseplate. I don't remember what those supposedly flow, but I'm pretty sure it's well below 1000 cfm. "
When I purchased my 1050 QF Annular Booster 4150 they claimed it would flow every bit of 1050 cfm. I think the QF/Pro-form main body is a different animal from the Holley.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859304
11/21/10 04:01 PM
11/21/10 04:01 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
My
The 950 verses the 850 w/o air horn will mph the same on your single plane intake, but the 950 might pick up the 60 ft, and mid track (shift recovery) performance. Maybe .1 sec. in et.
Test it out and let us know.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Jeremiah] #859305
11/21/10 04:05 PM
11/21/10 04:05 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Jeremiah,did you have it flow-tested to see exactly what it flows??? How do you like it? I want more air flow..without hurting streetability,even though I run a 4:56 gear and a 9.5" torque converter! If I can get a couple of mph,and still have low-speed throttle response...I'll be a happy camper!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859306
11/21/10 04:06 PM
11/21/10 04:06 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Hey Randy I think the Big L is open one more weekend??????
Let me know if ya wanna go testing
Gary.
Re: CARB CHANGE EXPECTATIONS??!!! [Re: BSB67] #859307
11/21/10 04:10 PM
11/21/10 04:10 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Russ! Early this week I'm going to change the pri. and sec. idle bleeds! Pri. to .080,and sec. to .078's! I'll let ya' know what I think about the change!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Mr340] #859308
11/21/10 04:13 PM
11/21/10 04:13 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks,Gary!...wish I could! My neck's still on the mend! VERY STIFF!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859309
11/22/10 01:32 AM
11/22/10 01:32 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I'm sorry to say that we never got that involved this year...or the last three for that matter. I'd love to see what it flows though. As far as street manners it is every bit as good as an 850 HP IMO. It would be cool if you could find one to try locally. I was very worried when I first looked down the throat of the carb. It's like looking through a tube! That said it idles nice and throttle response is good at low speeds. If you can't find one to try locally perhaps we can work something out?
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Jeremiah] #859310
11/22/10 02:20 AM
11/22/10 02:20 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks Jeremiah! I went on QF's web site and couldn't find the 1050 main body! Am I missing something??? Jeremiah...could you steer me in the right direction? Thanks!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859311
11/22/10 02:54 AM
11/22/10 02:54 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I purchased an entire carb from Summit. Prior to that I was using a 1050AN Mian body from ProForm. On one site the casting has "ProForm" and on the other is has "QFt". They are one in the same as far as I know. If you select the "360 deg. view" link above the product picture you will see what I mean concerning the cast-in logo's.
Here is the link at Summit Racing :
Down Leg
Annular
Look at that venturi~
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Jeremiah] #859312
11/22/10 06:05 AM
11/22/10 06:05 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i just tried a ultra hp950 against my mighty demon 825
on my package i lost about 3/10's and 3-4 mph.just did not get it done.did chassis dyno a tad over 400rwhp
it did seem to want to run richer than the demon
go figure
good luck
Tex
ps.just ran a new pb 11.308 on sunday.crap i broke out
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: CARB CHANGE EXPECTATIONS??!!! [Re: tex013] #859313
11/22/10 01:06 PM
11/22/10 01:06 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the info,Tex! Congrats on your new best..too bad ya' broke out!
Re: CARB CHANGE EXPECTATIONS??!!! [Re: Labratt] #859314
11/22/10 01:53 PM
11/22/10 01:53 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Randy I doubt you would see much if any change.
It's confusing but the 850 flows more than a 950.
Talk to Dwayne about this. Now if you could borrow/buy a 1050 Dom. you probably would see mph difference.
I remember Dwayne saying in just about every combo a WELL tuned Dom. will outperform a 4150!
OK you dirty rat you! sorry just had to say it.
Don
Page 1 of 4 1 2 3 4
