Re: CARB CHANGE EXPECTATIONS??!!!
[Re: Labratt]
#859296
11/21/10 02:19 PM
11/21/10 02:19 PM
Posts: 12,074 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Well, that would depend. If you can borrow a carb, you absolutely should try more CFM. As for buying carbs to test, not unless you're made of money. My 500" wedge gained just over 1 mph in the 1/8 going from a 950 to a 1050 Dominator. I don't remember exactly what my gain was when I went from an 850 to the 950. But it seems like a mile an hour or so. How big a carb, type of spacer (if any), type of boosters, etc. are best determined through testing.
Master, again and still
[Re: AndyF]
#859301
11/21/10 03:31 PM
11/21/10 03:31 PM
Posts: 1,049 ohio
all spooled up
ohio
A 950HP is smaller than an 850 DP. The 1000HP is basically the same carb as a 850 DP. So I'd say that you wouldn't see much difference at all between those carbs unless one of them wasn't set up correctly.
The 950HP is probably the best carb to run on the street but it might slow you down just a tad at the drags. Typically the 950HP will run better than a 850 DP on the street unless you have more than 500 ci.
ANDY can you tell us how the 950 is differed than the 850 it flows less
[Re: all spooled up]
#859303
11/21/10 03:57 PM
11/21/10 03:57 PM
Posts: 9,099 Rogue River, OR
Jeremiah
Rogue River, OR
Quoted from Captain Budget:
A Holley "950 HP" is basically a streamlined 750-size (1.38" venturi) main body w/ an 850 (1.75") baseplate. IIRC, that's worth 820-840 cfm from what those who have flow-tested them have said.
A Holley "1000 HP" is a streamlined 850-size (1.56" venturi) main body w/ a 1.75" baseplate. I don't remember what those supposedly flow, but I'm pretty sure it's well below 1000 cfm. "
When I purchased my 1050 QF Annular Booster 4150 they claimed it would flow every bit of 1050 cfm. I think the QF/Pro-form main body is a different animal from the Holley.
[Re: Labratt]
#859304
11/21/10 04:01 PM
11/21/10 04:01 PM
Posts: 4,313 Prospect, PA
BSB67
Prospect, PA
My The 950 verses the 850 w/o air horn will mph the same on your single plane intake, but the 950 might pick up the 60 ft, and mid track (shift recovery) performance. Maybe .1 sec. in et. Test it out and let us know.
[Re: Labratt]
#859309
11/22/10 01:32 AM
11/22/10 01:32 AM
Jeremiah
Rogue River, OR
Jeremiah,did you have it flow-tested to see exactly what it flows??? How do you like it? I want more air flow..without hurting streetability,even though I run a 4:56 gear and a 9.5" torque converter! If I can get a couple of mph,and still have low-speed throttle response...I'll be a happy camper!
I'm sorry to say that we never got that involved this year...or the last three for that matter. I'd love to see what it flows though. As far as street manners it is every bit as good as an 850 HP IMO. It would be cool if you could find one to try locally. I was very worried when I first looked down the throat of the carb. It's like looking through a tube! That said it idles nice and throttle response is good at low speeds. If you can't find one to try locally perhaps we can work something out?
[Re: Jeremiah]
#859312
11/22/10 06:05 AM
11/22/10 06:05 AM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
i just tried a ultra hp950 against my mighty demon 825 on my package i lost about 3/10's and 3-4 mph.just did not get it done.did chassis dyno a tad over 400rwhp it did seem to want to run richer than the demon go figure good luck Tex ps.just ran a new pb 11.308 on sunday.crap i broke out
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Labratt]
#859314
11/22/10 01:53 PM
11/22/10 01:53 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Randy I doubt you would see much if any change. It's confusing but the 850 flows more than a 950. Talk to Dwayne about this. Now if you could borrow/buy a 1050 Dom. you probably would see mph difference. I remember Dwayne saying in just about every combo a WELL tuned Dom. will outperform a 4150! OK you dirty rat you! sorry just had to say it. Don
