These are the pistons I ordered. 440Source list the dish at 24cc's. Ron
http://store.440source.com/Platinum-Series-Pistons-4350-24-Dished/productinfo/5080/
What effect is that much dish going to have on your CR? I thought you were going to shoot for 11.0:1.
I am shooting for around 11.0. When I changed to the Indy EZ heads the comp went up as they have 75cc heads vs the Eddy 84cc so I could not get it lower then 11.8 with quench. I can get it at 10.8 real easy with these pistons so I decided to go with them and 10.8 since it will be a pump gas eng. Ron
