Page 3 of 3 1 2 3
Re: Brake pressure at caliper...700 psi?---SOLVED [Re: karls67gtx] #859046
12/12/10 12:32 AM
12/12/10 12:32 AM
hooziewhatsit Online content
hooziewhatsit  Online Content
Thanks for the update. Good to hear you (mostly) figured it out.
Once it gets warm again I'll have to find a pressure gauge and take a look at mine.
Re: Brake pressure at caliper...700 psi?---SOLVED [Re: karls67gtx] #859047
12/13/10 07:56 PM
12/13/10 07:56 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
kool
Re: Brake pressure at caliper...700 psi?---SOLVED [Re: Dakota_Don] #859048
12/13/10 07:56 PM
12/13/10 07:56 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
what kinda gauge did you use??
Re: Brake pressure at caliper...700 psi?---SOLVED [Re: Dakota_Don] #859049
12/13/10 09:26 PM
12/13/10 09:26 PM
Smith Mtn Lake, VA
K
karls67gtx Offline OP
K
Smith Mtn Lake, VA
the SSBC kit, I think I ordered it from Summit. works great!
-karl
Re: Brake pressure at caliper...700 psi?---SOLVED [Re: karls67gtx] #859050
12/13/10 09:54 PM
12/13/10 09:54 PM
BDW Offline
BDW  Offline
Good info, how did you measure the pressure at the caliper?
Replace the bleeder valve with the gauge?
Re: Brake pressure at caliper...700 psi?---SOLVED [Re: BDW] #859051
12/13/10 09:56 PM
12/13/10 09:56 PM
If it was this gauge, it sure looks like you unscrew the bleeder and put the adapter in it. If you uncap the MC, you won't even have to bleed it again when you're done; just let it gravity bleed.
http://www.summitracing.com/parts/SSB-A1704/
I think I have something else on my wishlist
Re: Brake pressure at caliper...700 psi?---SOLVED [Re: BDW] #859052
12/13/10 10:05 PM
12/13/10 10:05 PM
since it's measuring psi rather than flow it only needs a miniscule opening (like a voltmeter only needs a very small gauge wire as opposed to an ammeter w large leads) so either the bleeder fitting or the hose whichever is easier to adapt a fitting to. www.northerntools.com has a 0-1500 psi glycerin filled gauge (grade B accuracy) for $13.99 (1/4 NPT male). and a grade A accuracy similar type gauge (1/8 NPT male) for $17.99. All major credit cards accepted. Plus a fitting (or 2) to plumb it in
Re: Brake pressure at caliper...700 psi?---SOLVED [Re: hooziewhatsit] #859053
12/13/10 10:10 PM
12/13/10 10:10 PM
BDW Offline
BDW  Offline
That was what I was leading up to, if you remove the bleeder valve and replace with a gauge, will the reading be correct?
Or do you need to plumb in a T to the bleeder valve, and bleed before measuring?
Re: Brake pressure at caliper...700 psi?---SOLVED [Re: BDW] #859054
12/13/10 10:15 PM
12/13/10 10:15 PM
Looking at the picture of the adapters, I'd think you would need to screw the adapter in first, let it fill up with fluid, then screw the gauge on.
Of course the rest of the brake system before that would have to be bled out.
Re: Brake pressure at caliper...700 psi?---SOLVED [Re: hooziewhatsit] #859055
12/13/10 10:29 PM
12/13/10 10:29 PM
An air bubble(s) will absorb psi as it collapses but I'd think it'd peak & you'd get a correct reading for a second (just like brakes will pump up briefly) but they need to be bled anyhow so I'd do that as said then take a reading.
Page 3 of 3 1 2 3
