Holley 3310? #858997
11/20/10 11:51 PM
11/20/10 11:51 PM
Mi.
G-Money1320 Offline OP
Mi.
Im not up on my carbs too well, but I just removed a Holley 3310 from a 73 Dart 340. So what carb is the list 3310? It has both metering plates but only a vaccuum secondary. Thanks
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Holley 3310? [Re: G-Money1320] #858998
11/20/10 11:57 PM
11/20/10 11:57 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Older ones were 780 and most of the new ones are 750 CFM from what I have read.They are a good reliable street/strip carb
Gus
64 Plymouth Savoy
Dana 60
Re: Holley 3310? [Re: G-Money1320] #858999
11/21/10 12:29 AM
11/21/10 12:29 AM
Locomotion Offline
Locomotion  Offline
It could be that someone removed the secondary metering plate and replaced it with a metering block, like in the front. OEM jetting is 72 primaries and would be 75 or 76 for the metering block in the secondary position.
Originally had a power valve up front but not in the secondaries.
Good all-around carbs. Tuned right, they might be only 1-2 tenths slower than a properly tuned 750 double pump carb.
Re: Holley 3310? [Re: G-Money1320] #859000
11/21/10 12:59 AM
11/21/10 12:59 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
One of my favorites as well. I've used them on everything from solid lifter 340's to bone stock 440's.
Sheldon
Re: Holley 3310? [Re: G-Money1320] #859001
11/21/10 11:25 AM
11/21/10 11:25 AM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
Another vote for the 3310 here. I went 119.75 mph this summer with one. It still had the choke plate in it too, lol.
As mentioned above, the 3310-1 is a 780 cfm. After that, they were 750 cfm(-2,-3, etc.)
Re: Holley 3310? [Re: G-Money1320] #859002
11/21/10 02:40 PM
11/21/10 02:40 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The 3310 is about the best street/strip carb out there for milder engines. Dirt cheap, easily tuned, fits nearly everything, and has no bad habits.
I will disagree that the vac sec 3310 will give up as much ET as was mentioned above. Except for particular circumstances, 750cfm is 750cfm and each should run similar if properly tuned. But, if the carb is to see street duty, the 3310 is a lot friendlier than the DP.
I have ran into the 7s in the 1/8 with 3310s.
If the carb is going to be on the street too, open the PVCRS and step the main jets down an equivalent amount. They are too rich on the cruise circuit. Not as bad as the DP, but enough that it needs addressed.
Adjust the balance between the mains and the PVCRs, tune the PV opening point, and dial in the secondary opening point and you have a rockin' carb.........for cheap.
Master, again and still
Re: Holley 3310? [Re: DaveRS23] #859003
11/21/10 10:42 PM
11/21/10 10:42 PM
Mi.
Mi.
Ok I did a little checking on this carb today, it has 72's in the front and 76's in the back. Its not a double pumper so why does it have a power valve in the rear plate?? It also has the round black lean adjuster on it. I want to say this car hasnt been on the road since around 78 and im gonna guess it wasnt much before it got wrecked that this carb was bought/put on.It's stamped 3310-1. Thanks for all your help, I think im going to try to restore and use this carb.
Re: Holley 3310? [Re: G-Money1320] #859004
11/21/10 11:08 PM
11/21/10 11:08 PM
Locomotion Offline
Locomotion  Offline
That's an original 3310 which was rated at 780! It came with a secondary metering block and the original power valves were 10.5 primary and 8.5 secondary. Jets you have are original.
Not familiar with the "lean adjuster".
Most double pumpers do not have a power valve in the secondaries but did have the metering block with jets.
3310-2 and later had a metering plate instead of a block and were rated at 750. Maybe a cost saving measure.
Not 100% sure, but I believe 3310 Holleys were used on some z-28's and/or big block Chevy's as well as being available as an aftermarket performance carb?
Re: Holley 3310? [Re: Locomotion] #859005
11/27/10 07:44 PM
11/27/10 07:44 PM
md
W
wicked Offline
wicked  Offline
W
md
many 3310-1 with secondary power valve were sold over the counter as gm 396 replacement carbs and as an all purpose "hp" carb
