info and pics! sb cross over oiling tube??????????help
#858484
11/20/10 12:37 PM
11/20/10 12:37 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
Re: info and pics! sb cross over oiling tube??????????help
[Re: RAY1969CARS]
#858485
11/21/10 01:10 AM
11/21/10 01:10 AM
Posts: 1,805 ky hills
thehemikid
ky hills
y ? how ? is there a kit ?
...Are you talking about this?
[Re: RAY1969CARS]
#858490
11/30/10 11:48 PM
11/30/10 11:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
here's mine.
looking at ur pic and the one in the book y is your on the other side ??? the book pic shows going to the front drivers side ? ps is that 3/8 hose ?????
Doesnt matter just as long as it jumps over... I have a block out in the shop with a jumper but mine is like the books shows... no big deal
[Re: MR_P_BODY]
#858491
11/30/10 11:50 PM
11/30/10 11:50 PM
Posts: 1,390 CA.
RAY1969CARS
CA.
[Re: RAY1969CARS]
#858492
12/01/10 12:01 AM
12/01/10 12:01 AM
MR_P_BODY
3/8 ??? line
I think mine is a -8 but could be a -6... the block its on has bushed lifter bores so its not loosing any oil but I think its -8
[Re: 3ddart]
#858494
12/07/10 02:26 AM
12/07/10 02:26 AM
thehemikid
ky hills
i'm interested in trying this setup instead of tubing the block. my ? is, in the 2nd pic hemikid shows it indicates the angle of the fitting into the block is critical. any info on this? thanks dave
...He didn't explain any farther in the article either.
[Re: RAY1969CARS]
#858497
12/07/10 02:47 AM
12/07/10 02:47 AM
dartman366
Mt. Vernon, Ohio
3/8 ??? line
no, it a 1/4" line, it only feeds the lifter's and rocker's so I kept it as small as I felt comfortable with, everything get's plenty of oil on top.
[Re: 3ddart]
#858499
12/09/10 11:50 AM
12/09/10 11:50 AM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
no info, opinions on this critical angle?
I believe "critical angle" is a term used to determine fixed angles. In other words, dont drill into the passage at a 55 degree angle if the fitting is 45 degrees.
