info and pics! sb cross over oiling tube??????????help #858484
11/20/10 12:37 PM
11/20/10 12:37 PM
CA.
RAY1969CARS Offline OP
CA.
y ? how ? is there a kit ?
Re: info and pics! sb cross over oiling tube??????????help [Re: RAY1969CARS] #858485
11/21/10 01:10 AM
11/21/10 01:10 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Are you talking about this?
Re: info and pics! sb cross over oiling tube??????????help [Re: thehemikid] #858486
11/21/10 01:14 AM
11/21/10 01:14 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...If so, this too.
Re: info and pics! sb cross over oiling tube??????????help [Re: thehemikid] #858487
11/21/10 01:16 AM
11/21/10 01:16 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
here's mine.
Re: info and pics! sb cross over oiling tube??????????help [Re: thehemikid] #858488
11/21/10 01:21 AM
11/21/10 01:21 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Copyright 1978, the yr I bought it.
Re: info and pics! sb cross over oiling tube??????????help [Re: dartman366] #858489
11/30/10 11:28 PM
11/30/10 11:28 PM
CA.
CA.
here's mine.
looking at ur pic and the one in the book y is your on the other side ??? the book pic shows going to the front drivers side ? ps is that 3/8 hose ?????
Re: info and pics! sb cross over oiling tube??????????help [Re: RAY1969CARS] #858490
11/30/10 11:48 PM
11/30/10 11:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
here's mine.
Doesnt matter just as long as it jumps over... I have
a block out in the shop with a jumper but mine is
like the books shows... no big deal
Re: info and pics! sb cross over oiling tube??????????help [Re: MR_P_BODY] #858491
11/30/10 11:50 PM
11/30/10 11:50 PM
CA.
CA.
3/8 ??? line
Re: info and pics! sb cross over oiling tube??????????help [Re: RAY1969CARS] #858492
12/01/10 12:01 AM
12/01/10 12:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
3/8 ??? line
I think mine is a -8 but
could be a -6... the block its on has bushed lifter
bores so its not loosing any oil but I think its -8
Re: info and pics! sb cross over oiling tube??????????help [Re: MR_P_BODY] #858493
12/06/10 12:05 PM
12/06/10 12:05 PM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
i'm interested in trying this setup instead of tubing the block. my ? is, in the 2nd pic hemikid shows it indicates the angle of the fitting into the block is critical. any info on this? thanks dave
Re: info and pics! sb cross over oiling tube??????????help [Re: 3ddart] #858494
12/07/10 02:26 AM
12/07/10 02:26 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...He didn't explain any farther in the article either.
Re: info and pics! sb cross over oiling tube??????????help [Re: thehemikid] #858495
12/07/10 02:28 AM
12/07/10 02:28 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
2
Re: info and pics! sb cross over oiling tube??????????help [Re: 3ddart] #858496
12/07/10 02:39 AM
12/07/10 02:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The only thing I can see about the angle is clearing
the casting... its got to fill the one side before it
jumps over and it doesnt make pressure till both sides
are full(full pressure) so other than clearing I
dont see any angle issue. My block that its on is
bushed and now I'm changing to push ro oiling so I
need to drill my bushings... now I need to find my
drilling tool for that
EDIT
I also glue screen in all of the valley drains too,
if anything breaks up top the screen stops it(at
least any big stuff), JB Weld works fine... even do
the back wall
Re: info and pics! sb cross over oiling tube??????????help [Re: RAY1969CARS] #858497
12/07/10 02:47 AM
12/07/10 02:47 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
3/8 ??? line
no, it a 1/4" line, it only feeds the lifter's and rocker's so I kept it as small as I felt comfortable with, everything get's plenty of oil on top.
Re: info and pics! sb cross over oiling tube??????????help [Re: dartman366] #858498
12/09/10 11:08 AM
12/09/10 11:08 AM
malvern, ohio
3
3ddart Offline
3ddart  Offline
malvern, ohio
no info, opinions on this critical angle?
Re: info and pics! sb cross over oiling tube??????????help [Re: 3ddart] #858499
12/09/10 11:50 AM
12/09/10 11:50 AM
Pacifica, CA
Devilbrad Offline
Devilbrad  Offline
Pacifica, CA
I believe "critical angle" is a term used to determine fixed angles. In other words, dont drill into the passage at a 55 degree angle if the fitting is 45 degrees.
Re: info and pics! sb cross over oiling tube??????????help [Re: dartman366] #858500
12/09/10 12:16 PM
12/09/10 12:16 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
3/8 ??? line
If you did your mod to the diagram shown in the book/illustration shown above. The new oil tube feed the #1 main bearing. Or did you install a plug after the #1 main, in the lh bank as it was to go up to the lh galley? Just curious.
