Tips on assembling socketless hose? #858436
11/20/10 02:21 AM
11/20/10 02:21 AM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
I have the black Aeroquip AQP socketless hose, the Aeroquip fittings, and the Aeroquip assembly lube. However, I can't seem to get the fitting fully seated. It is about 1/4" from full in.
Are they any tricks to doing this assembly? I am lubricating both the inside of the hose, and the barbed end of the fitting. I am pushing as hard as I can on a hose (already busted up several fingers when the hose bent suddenly), but can't get the darn things complete.
I thought this hose system was "easy to assemble" and am assuming I am doing something wrong.
Help!
Re: Tips on assembling socketless hose? [Re: davenc] #858437
11/20/10 02:40 AM
11/20/10 02:40 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I use the similar Earl's stuff - collar goes over the end of the hose, hose goes onto a barbed fitting - and the thing that works for me is brushing some STP on the barb and a little bit on the ID of the hose. Fitting on a non-marring surface, push the hose (with collar over its end) on with a bit of effort, done. I used to have a harder time of it with any other lubricant.
Re: Tips on assembling socketless hose? [Re: topside] #858438
11/20/10 02:47 AM
11/20/10 02:47 AM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
I think I might have some STP in the garage. I will try that on the next one I try to assemble. I still need to get the first hose complete though!
Does the age of the hose make it harder to assemble? The hose I have is about 1 year old.
Thanks, Dave
Re: Tips on assembling socketless hose? [Re: davenc] #858439
11/20/10 03:45 AM
11/20/10 03:45 AM
AndyF Offline
AndyF  Offline
warm the hose up a little bit with a heat gun.
Re: Tips on assembling socketless hose? [Re: AndyF] #858440
11/20/10 07:31 AM
11/20/10 07:31 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
That's what I do!
Mopar Performance
Re: Tips on assembling socketless hose? [Re: AndyF] #858441
11/20/10 07:37 AM
11/20/10 07:37 AM
K&Q va.
BIGBLOCK_KAT Offline
K&Q va.
Check and make sure the nipple that is going into the hose has not dug into the hose liner. Also another problem is certain hoses must not be to close to the socket base as it will bottom out before the assy. is drawn up. I know you said socketless, but just in case.
Re: Tips on assembling socketless hose? [Re: AndyF] #858442
11/20/10 09:24 AM
11/20/10 09:24 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
If you like drag racing, support your local track.
Re: Tips on assembling socketless hose? [Re: CHAPPER] #858443
11/20/10 11:22 AM
11/20/10 11:22 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yep a little heat from a heat gun a little lube and they slide right together
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Tips on assembling socketless hose? [Re: dusturbd340W5] #858444
11/20/10 11:38 AM
11/20/10 11:38 AM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
Thanks everyone for the tips! It was a little chilly in the garage last evening, and I guess that wasn't helping any.
Re: Tips on assembling socketless hose? [Re: davenc] #858445
11/20/10 04:25 PM
11/20/10 04:25 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I dip the hose in hot water for a minute or two and on we go! Socketless hose rules!
Re: Tips on assembling socketless hose? [Re: Jeremiah] #858446
11/20/10 10:55 PM
11/20/10 10:55 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
How hot is the water? Today I tried heating up the hose with a 1800W hair dryer. I got the hose hot enough that it was difficult to hold for any length of time even with my mechanic's gloves. On top of that it was still almost impossible to close that last 1/4" gap on the fitting. From what everyone is saying, it should be easier than this!
Which brand of socketless hose did you use? I don't know if it is something I am doing wrong, but at the moment, I am not impressed with the Aeroquip hose. Its rated to 250PSI, and there is no way this stuff is coming apart. However, I'm just trying to use it in my fuel system.
Re: Tips on assembling socketless hose? [Re: davenc] #858447
11/21/10 01:44 AM
11/21/10 01:44 AM
Kissimmee Fl.
Kissimmee Fl.
I use nothing but the Aeroquip hose with a true heat gun not a hair dryer and have 0 problems getting the fittings in.You have to heat the hose back far enough to equal the fitting length
Re: Tips on assembling socketless hose? [Re: AndyF] #858448
11/21/10 02:18 AM
11/21/10 02:18 AM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
No need to use hot water or a heat gun. Made hundreds of push on hose assemblies and only used 80-90w gear lube.
However, I will say that Aeroquip ends are the worst push on fittings to assemble from personal experience. The barbs are bigger when compared to others and takes a little more effort to get the hose to seat.
Connect a fitting to the hose end and secure it in a vise for a better base to push against. The most important part is to make sure you coat the barbs with plenty of lube. Give the hose a little wiggle from side to side as you push the hose over the barbs and you should be able to slide it right on.
Yes, it is a little like pushing rope, but once you get the hang of it (individual technique and a few F bombs) it becomes a snap.
Re: Tips on assembling socketless hose? [Re: jb500] #858449
11/21/10 12:06 PM
11/21/10 12:06 PM
Kissimmee Fl.
Kissimmee Fl.
sure you can get them on without heating the hose but it makes it so much easier why not do it they just slide right on no wiggling no F-Bombs
Re: Tips on assembling socketless hose? [Re: dusturbd340W5] #858450
11/21/10 12:48 PM
11/21/10 12:48 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
True, and you can also use a sledgehammer to pound in finish nails. Not the best tool or technique, but it still gets the job done.
Plenty of lube in the hose and on the barbs will get the job done.
Re: Tips on assembling socketless hose? [Re: jb500] #858451
11/21/10 02:47 PM
11/21/10 02:47 PM
Kissimmee Fl.
Kissimmee Fl.
sure you can also roll a flat tire but it is easier if you put air in it and heating the hose has no adverse affects on it but to each there own I chose the easy way.
Re: Tips on assembling socketless hose? [Re: dusturbd340W5] #858452
11/21/10 04:10 PM
11/21/10 04:10 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Re: Tips on assembling socketless hose? [Re: jb500] #858453
11/21/10 05:39 PM
11/21/10 05:39 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
The water I used was just from the tap on the hottest setting. If you are having trouble perhaps try some WD40 or some other cheap lubricant. It does take lots of grunt on my part but they always go together. The only reason I did not use oil is because it is messy and slippery. I'd imagine that works just fine.
Re: Tips on assembling socketless hose? [Re: Jeremiah] #858454
11/21/10 06:33 PM
11/21/10 06:33 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
Slippery....that is the reason gear oil works just fine.
Heat, no heat, hot water, no water....whatever works for you is fine. Just saying that working in the hyd hose and fitting world since 99 and not once during mfg training or real world experience has a heat gun or hot water been advised or used for socketless(push-on fittings). We always had the correct tools (pushers and mandrels)to do the job and maybe that is where the difference lays here.
Re: Tips on assembling socketless hose? [Re: jb500] #858455
11/21/10 09:33 PM
11/21/10 09:33 PM
NC, USA
davenc Offline OP
davenc  Offline OP
NC, USA
OK, I finally got the first three hoses assembled. Ended up putting the fitting into a vice and then pushing down on the hose after lubing and heating the hose with a hair dryer. All the fittings are now fully seated.
It was still an adventure with the 45 and 90 degree fittings I was using, since it was rather difficult to get them into the vice in a position that I could then get good downward force on.
I had some Summit fittings and the barbs are a smaller diameter than the Aeroquip fittings. However, I went with the Aeroquip fittings because I could get them with female AN ends. With the Summit fittings, I would have needed a coupler since I only had male AN ends on the hose barb.
I still need to assemble the hoses back at the tank, but at less those are straight fittings. I really like the idea of the socketless hose, but next time I am look further for different fittings.
Thanks to all for the help!
