any one ever used safe -t-caps to cap a frame #857643
11/19/10 03:08 AM
11/19/10 03:08 AM
littlestown pa
dustpan man Offline OP
littlestown pa
i got a duster the k frame broke through the unibody frame what caps work best of if i should buy nice orignal ones i want to cap the rear two spring hangers to never did this before
Re: any one ever used safe -t-caps to cap a frame [Re: dustpan man] #857644
11/19/10 03:14 AM
11/19/10 03:14 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
they look like crap and fit horrible! waste of time and money if you ask me..
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: any one ever used safe -t-caps to cap a frame [Re: mopars_1] #857645
11/19/10 03:26 AM
11/19/10 03:26 AM
littlestown pa
littlestown pa
thanks
Re: any one ever used safe -t-caps to cap a frame [Re: dustpan man] #857646
11/19/10 03:59 AM
11/19/10 03:59 AM
Lake Elmo, MN
Evil Monkey Offline
Evil Monkey  Offline
Lake Elmo, MN
I used an Auto Rust Technicians cap (I believe those are the Safe-T-Caps you are referring to) on the back half of the drivers front frame rail on my Cuda. It fit well and has held up fine for about 10 years now, and I have no complaints.
However, after getting the cap from them, I realized it was just 3 pieces of steel welded together to make the cap, and that it was something I could have fabricated myself for about 10 percent of what they charged. I have since made my own caps for the two rear spring hangers out of some steel stock that I had on hand, and they are easily as strong as anything someone could sell to me, but it did take some time to do the fabrication. If you have more time than money - make your own, but if you have more money than time - buy them pre made.
The K frame section of the frame might be something that you would want to buy, though - depends on your fabricating skills. I'm not sure if the caps are good for this area, or if you would be better off getting a new front frame rail, or a section of a frame rail to splice in. But if you're a good fabricator, I would think this section could be fabbed up also.
1974 'Cuda 360/TKO 1990 Ram Van 1998 Neon
Re: any one ever used safe -t-caps to cap a frame [Re: Evil Monkey] #857647
11/19/10 11:18 AM
11/19/10 11:18 AM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
Same here. Used Auto Rust Tech's caps and they are fine. Not a perfect fit but they are close. They are also 13 gauge steel which is slightly heavier than what the factory used. My bodyman tells me this car certainly isn't going to be twisting with these, the torque boxes, and frame conectors.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: any one ever used safe -t-caps to cap a frame [Re: klunick] #857648
11/19/10 12:59 PM
11/19/10 12:59 PM
Bel Air Maryland USA 21014
wmwalden Offline
wmwalden  Offline
Why not weld three plates on the rail. Both sides and the bottom. Go 6 inches past the break and call it done.
Re: any one ever used safe -t-caps to cap a frame [Re: wmwalden] #857649
11/19/10 02:40 PM
11/19/10 02:40 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
That works as long as the area you are capping is flat. What you gonna do for the area over the axles? For me it was just easier to buy what I needed.
Re: any one ever used safe -t-caps to cap a frame [Re: Evil Monkey] #857650
11/20/10 05:58 PM
11/20/10 05:58 PM
Columbus Ga
reflections7 Offline
Columbus Ga
Same here I could have made it myself for 10 percent of what they charge. They work but that is all I will say.
Re: any one ever used safe -t-caps to cap a frame [Re: dustpan man] #857651
12/07/10 03:19 PM
12/07/10 03:19 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Can anyone tell me what the original frame rail metal thickness is?
How many thousands or gage thickness?
Thank you.
Ola
