Hemi exhaust manifolds.. #85737
07/08/08 10:49 AM
07/08/08 10:49 AM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Anyone out there have a set of reproduction hemi exhaust manifolds? I have read that there are a couple of companies making them. Who's are the best? Any fitment issues on E bodys? Any help appreciated.
Re: Hemi exhaust manifolds.. [Re: PJM] #85738
07/08/08 02:27 PM
07/08/08 02:27 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
i have a set , haven't installed them yet in anything ,
contact HemiFred
Re: Hemi exhaust manifolds.. [Re: PJM] #85739
07/08/08 02:59 PM
07/08/08 02:59 PM
Newfoundland
Crocker Offline
Crocker  Offline
Newfoundland
I got mine through Mancinis. Fit was fine although it took a bit of shoehorning to put the engine in the car.
Re: Hemi exhaust manifolds.. [Re: Crocker] #85740
07/08/08 04:24 PM
07/08/08 04:24 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
I agree with John( did I just say that? LOL)
PM Hemifred, got mine thru him. Fit perfect in a chassis they weren't even designed for.
Butch
Re: Hemi exhaust manifolds.. [Re: Crocker] #85741
07/08/08 04:30 PM
07/08/08 04:30 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Did you guys install the engine from the top or removing the k member?
Re: Hemi exhaust manifolds.. [Re: PJM] #85742
07/08/08 07:36 PM
07/08/08 07:36 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I bought and use a set from Mancini, no problems in two years. It's a bit cramped tightening up the bolts between #1 and #3 with Power Steering but no big deal.
Sheldon
Re: Hemi exhaust manifolds.. [Re: PJM] #85743
07/08/08 10:28 PM
07/08/08 10:28 PM
I would guess they are all made by one vendor.Can't imagine more than one tooling for something like a set of manifolds.
Re: Hemi exhaust manifolds.. [Re: PJM] #85744
07/09/08 09:55 AM
07/09/08 09:55 AM
Jacksonville, Fl
426runner Offline
426runner  Offline
Jacksonville, Fl
I had a little trouble with mine. Bought from YO a few years back. Had to elongate a hole or 2... and there was a radius I had to cut down for a bolt/washer to seat flat. Also, at the outlets where the headpipes mount were not the smoothest surfaces. In fact, there were good sized ridges where it looked like the mold halves came together. Maybe YO sold me "seconds" or rejects. As far as fitting in the car, no issues.
Later, Sandy '70 HEMI Road Runner B5/B5, 4 spd "Sandy's Garage" on Facebook
Re: Hemi exhaust manifolds.. [Re: 426runner] #85745
07/14/08 07:14 AM
07/14/08 07:14 AM
JohnRR Offline
JohnRR  Offline
good reply , i'll have to pull mine out of the box and check these spots and correct them now .
Re: Hemi exhaust manifolds.. [Re: JohnRR] #85746
07/14/08 07:37 AM
07/14/08 07:37 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
I was out at the charlotte autofair in may and one old boy had a set from YO, dirty, rusty, laying in the wet grass. 'Wanted $800 for them. 'Think I insulted him when I offered $500. I ended up buying a set new in the box for $550, plus $30 shipping from a guy on ebay. They're bare. No heat riser, but I didn't want one anyway. He did include a block off plate for the heat tube already installed which was good because I don't want to run heat tubes either. Haven't test fitted yet but they look good. Anybody see those off a 70 hemicuda that brought $5500 on ebay a few weeks ago? 'Wish I had a train car load of that stuff to SELL...
Re: Hemi exhaust manifolds.. [Re: Silverbullet2] #85747
07/14/08 12:14 PM
07/14/08 12:14 PM
JohnRR Offline
JohnRR  Offline
You'd also need a train load of to buy them ...
Re: Hemi exhaust manifolds.. [Re: JohnRR] #85748
07/14/08 04:05 PM
07/14/08 04:05 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Thanks for the info. Its funny to think that the first thing we did in the 70's was ditch these things for headers. Now there worth there weight in gold!
Re: Hemi exhaust manifolds.. [Re: PJM] #85749
07/14/08 04:17 PM
07/14/08 04:17 PM
Jacksonville, Fl
426runner Offline
426runner  Offline
Jacksonville, Fl
Re: Hemi exhaust manifolds.. [Re: 426runner] #85750
07/14/08 04:39 PM
07/14/08 04:39 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Thanks Sandy! Thats what I needed to see. Its going in from the bottom.
Re: Hemi exhaust manifolds.. [Re: PJM] #85751
07/15/08 02:31 PM
07/15/08 02:31 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I had problems with a set from Year-One last year on a car. I couldn't get them to seal to the H-pipe. After pulling things apart and looking for the problem I discovered that the repro mainfolds have a much more tapered looking flange. An original manifold has a more rounded edge. The design is set-up to be a ball and socket seal so you don't have to use a gasket. Problem is that the repro manifold edge isn't cast enough to look like the socket it needs to be. Sure GLAD I picked up a pair old original manifolds last week for only $400 so I don't have to deal with that problem again!
Re: Hemi exhaust manifolds.. [Re: hemi70se] #85752
07/15/08 02:47 PM
07/15/08 02:47 PM
Jacksonville, Fl
426runner Offline
426runner  Offline
Jacksonville, Fl
I had problems with a set from Year-One last year on a car. I couldn't get them to seal to the H-pipe. After pulling things apart and looking for the problem I discovered that the repro mainfolds have a much more tapered looking flange. An original manifold has a more rounded edge. The design is set-up to be a ball and socket seal so you don't have to use a gasket. Problem is that the repro manifold edge isn't cast enough to look like the socket it needs to be.... snip...
How did you solve the ploblem??
Re: Hemi exhaust manifolds.. [Re: 426runner] #85753
07/15/08 11:42 PM
07/15/08 11:42 PM
Minneapolis, MN
hemi70se Offline
hemi70se  Offline
Minneapolis, MN
I had to have new front sections of the H-pipe made that could seal to those repro manifolds. I wasn't happy about spending the $200 it cost me either!
Re: Hemi exhaust manifolds.. [Re: hemi70se] #85754
07/17/08 06:58 AM
07/17/08 06:58 AM
North Carolina, USA
North Carolina, USA
Update... I was up at John Arruzza's shop on monday. 'Carried the new manifolds with me and we decided to check the fit on one of my heads. All the holes will need to be slotted .150-.200. Core shift or what? Who knows about the pipe flange. Also Arruzza had bought roller lifters for my engine months ago. He happened to figure out the tie bar on Crower lifters hits the lifter boss on the block before it even touches the lobes. Mopar keeps making that area bigger on the blocks and it's not a world block either. He finally found a set of Isky lifters that will work, but more $. The repro industry definitely needs to get on the ball here.... Whether it's engine blocks, exhaust manifolds, seat foams, or sheet metal there are too many high dollar parts being sold that DON'T fit.
Re: Hemi exhaust manifolds.. [Re: Silverbullet2] #85755
07/17/08 08:56 AM
07/17/08 08:56 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I've posted more than once on reproduction parts.If you have an original part as a pattern,there is no d@mn reason for it not to be made right.
Re: Hemi exhaust manifolds.. [Re: 62maxwgn] #85756
07/17/08 07:21 PM
07/17/08 07:21 PM
michigan woods
imfixinmopars426 Offline
michigan woods
contact mfp for the manifolds,different mfg from the yr1 units,better i think.734.658.5841 he was in mcg running ads.
