Re: Hemi exhaust manifolds..
[Re: PJM]
#85743
07/08/08 10:28 PM
07/08/08 10:28 PM
Anyone out there have a set of reproduction hemi exhaust manifolds? I have read that there are a couple of companies making them. Who's are the best? Any fitment issues on E bodys? Any help appreciated.
I would guess they are all made by one vendor.Can't imagine more than one tooling for something like a set of manifolds.
[Re: PJM]
#85744
07/09/08 09:55 AM
07/09/08 09:55 AM
Posts: 368 Jacksonville, Fl
426runner
Jacksonville, Fl
I had a little trouble with mine. Bought from YO a few years back. Had to elongate a hole or 2... and there was a radius I had to cut down for a bolt/washer to seat flat. Also, at the outlets where the headpipes mount were not the smoothest surfaces. In fact, there were good sized ridges where it looked like the mold halves came together. Maybe YO sold me "seconds" or rejects. As far as fitting in the car, no issues.
Later, Sandy
'70 HEMI Road Runner B5/B5, 4 spd
"Sandy's Garage" on Facebook
[Re: 426runner]
#85745
07/14/08 07:14 AM
07/14/08 07:14 AM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
good reply , i'll have to pull mine out of the box and check these spots and correct them now .
[Re: Silverbullet2]
#85747
07/14/08 12:14 PM
07/14/08 12:14 PM
JohnRR
U.S.S.A.
I was out at the charlotte autofair in may and one old boy had a set from YO, dirty, rusty, laying in the wet grass. 'Wanted $800 for them. 'Think I insulted him when I offered $500. I ended up buying a set new in the box for $550, plus $30 shipping from a guy on ebay. They're bare. No heat riser, but I didn't want one anyway. He did include a block off plate for the heat tube already installed which was good because I don't want to run heat tubes either. Haven't test fitted yet but they look good. Anybody see those off a 70 hemicuda that brought $5500 on ebay a few weeks ago? 'Wish I had a train car load of that stuff to SELL...
You'd also need a train load of to buy them ...
[Re: Silverbullet2]
#85755
07/17/08 08:56 AM
07/17/08 08:56 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Update... I was up at John Arruzza's shop on monday. 'Carried the new manifolds with me and we decided to check the fit on one of my heads. All the holes will need to be slotted .150-.200. Core shift or what? Who knows about the pipe flange. Also Arruzza had bought roller lifters for my engine months ago. He happened to figure out the tie bar on Crower lifters hits the lifter boss on the block before it even touches the lobes. Mopar keeps making that area bigger on the blocks and it's not a world block either. He finally found a set of Isky lifters that will work, but more $. The repro industry definitely needs to get on the ball here.... Whether it's engine blocks, exhaust manifolds, seat foams, or sheet metal there are too many high dollar parts being sold that DON'T fit.
I've posted more than once on reproduction parts.If you have an original part as a pattern,there is no d@mn reason for it not to be made right.
