Tunnel ram help #857196
11/18/10 03:38 PM
11/18/10 03:38 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
I have a tunnel ram with 2 Holley 750 DP carbs on my 505 inch motor. I put a set of spark plugs in and took the car out and drove it all day. The car ran okay for the most part, it dose not idle very well in gear. Anyway I pulled the plugs and noticed that the front of the motor
(plugs 1,2,3 & 4) are running lean and the back plugs are running rich. The carbs are set up exactly the same. When the motor is warm I turn in the mixture screws in until the motor stumbles and then I back them out ½ turn. What would cause this? Is this common? Should I just back out the mixture screws some more on the front carb and turn them in on the back?
Thanks.
Re: Tunnel ram help [Re: Harley] #857197
11/18/10 04:53 PM
11/18/10 04:53 PM
Guitar Jones Offline
Need more info, is this a brand new set up or was it used. Has it been on your engine for awhile?
What I'm getting at is it sounds like the carbs may not be the same or they could be dirty, the float levels may be off, so many possibilities.
Re: Tunnel ram help [Re: Guitar Jones] #857198
11/18/10 04:55 PM
11/18/10 04:55 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
what type of linkage? is there flex?
What about the idle setup - they have to be the same - so how are you setting the idle?
Re: Tunnel ram help [Re: Guitar Jones] #857199
11/18/10 06:04 PM
11/18/10 06:04 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
The carbs have been on for a while. They are 750dp list # 6109. I had water issues in the past and replaced the old gas tank. I also had to take the carbs apart and clean all the [Edited by Moparts - Family Friendly Site - Keep it clean] out of them. The float levels are fine. They sit sideways on a Weiand hi-ram intake.
Re: Tunnel ram help [Re: DJVCuda] #857200
11/18/10 06:08 PM
11/18/10 06:08 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
The linkage seems to be fine. They both have 1 ½ turns out on the idle mixture screws.
Re: Tunnel ram help [Re: Harley] #857201
11/18/10 06:16 PM
11/18/10 06:16 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
What I mean about the idle being bad is the motor idles at 1100 rpm in park, and when you put it in gear it drops to 900rpm and starts to fall from there. I have to drive with 2 feet. The timing is locked. It makes about 7 inches of vacuums in park. I forgot to mention it has a flat tappet solid cam in it .613 lift 278@.050.
Re: Tunnel ram help [Re: Harley] #857202
11/18/10 06:29 PM
11/18/10 06:29 PM
Mansfield,Ohio
Brandon70cuda Offline
Mansfield,Ohio
Sounds a bit like a vacuum leak. Would explain the front being lean and the idle. Carb base gasket leaking maybe?
Re: Tunnel ram help [Re: Brandon70cuda] #857203
11/18/10 06:47 PM
11/18/10 06:47 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
What’s the best way to check for a vacuum leak?
Re: Tunnel ram help [Re: Harley] #857204
11/18/10 06:52 PM
11/18/10 06:52 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Spray wd-40 any where you suspect a leak. The engine will pick up rpm as it is sucked in and burnt.
Re: Tunnel ram help [Re: Harley] #857205
11/18/10 07:42 PM
11/18/10 07:42 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Mistake #1.
Where are the throttle disc vs. transition holes at idle?
PV, Y/N?
Do you have a balance tube between the front and rear float bowls?
Boffin Emeritus
Re: Tunnel ram help [Re: polyspheric] #857206
11/18/10 08:04 PM
11/18/10 08:04 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I would look into the back carb ,see if its dumping fuel in or it has an issue
block the two outer air holes on the top see if the carb reacts to it
1.39 9.85 - 137 mph
Re: Tunnel ram help [Re: polyspheric] #857207
11/18/10 08:48 PM
11/18/10 08:48 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
Mistake #1.
PV, Y/N?
The throttle blades are not close to the transfer slot. I have no p/v. Why is locked timing a mistake?
Re: Tunnel ram help [Re: Ari440] #857208
11/18/10 08:52 PM
11/18/10 08:52 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
No it is not dumping any fuel, the floats are set correctly. And the motor dose slow down when blocking the air bleeds.
Re: Tunnel ram help [Re: Harley] #857209
11/18/10 09:07 PM
11/18/10 09:07 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
try switching the carbs and run them for a while . See if the problem follows the carb.
Re: Tunnel ram help [Re: VanishPt] #857210
11/18/10 09:19 PM
11/18/10 09:19 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Very good idea in my opinion.
Re: Tunnel ram help [Re: mac56] #857211
11/18/10 09:42 PM
11/18/10 09:42 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
I see two new metering plates in your future !
one of them is running rough
1.39 9.85 - 137 mph
Re: Tunnel ram help [Re: mac56] #857212
11/18/10 10:06 PM
11/18/10 10:06 PM
Queens, New York
Harley Offline OP
Harley  Offline OP
Queens, New York
That is a very good idea. I will switch them up on Sunday.
Re: Tunnel ram help [Re: Harley] #857213
11/19/10 12:12 AM
11/19/10 12:12 AM
Cab_Burge Online work
Cab_Burge  Online Work
When you have both carbs off look at all four sets of butterflys on the throttle shafts, use a feeler gauge to see if there opened the same(front and rear on both carbs.) on the idle circuits, if not adjust them so they are BTW, di dyou buy those carbs new or used? If used look at the idle and high speeds bleeds as well as the idel fuel restrictors in the metering blocks The RPM drop sounds good but it may be loading up aftet idling a small amount of time in gear
