69 Hemi master cylinder cover??
#856928
11/18/10 11:33 AM
11/18/10 11:33 AM
Posts: 579 Wattsburg, Pa
Dr V
Wattsburg, Pa
Anyone know what color the cover is supposed to be on a 69 hemi m/c cover. I thought some shade of light gold. Thanks Eric
69 1/2 A12 BEE 4 spd 1968 Charger 383 1970 Roadrunner 440+6 Survivor 2019 Redeye 2005 FORD GT Red/White 2017 Viper ACR Extreme Red/White 1979 Branco Red/Red 2018 Porsche GT3 Miami 1971 440+6 Cuda 4 speed V2 2020 Sebring Orange Vette 1979 Chevy Boogie Hippie Van
Re: 69 Hemi master cylinder cover??
[Re: gtx6970]
#856930
11/18/10 12:15 PM
11/18/10 12:15 PM
Dr V
Wattsburg, Pa
Bill, it is a power disc car, So all gloss black for m/c, lid, and booster then?
[Re: LimeliteAero]
#856932
11/18/10 01:22 PM
11/18/10 01:22 PM
Posts: 543 Indiana, Just Off I-70
BradD
Were the brackets assembled on the rear of the booster before paint? I mean all pins, pivots, and brackets would have been assembled before paint up to the firewall reinforcement plate? Or would the offset brackets and pivot(fulcrum) have been added after paint so the nuts and pins would not be painted? Actually as I type(slowly) I realize they probably(speculation) would have been assembled after paint since other BB cars without the offset also got this booster and MC. Brad
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: gtx6970]
#856933
11/18/10 02:53 PM
11/18/10 02:53 PM
Posts: 4,799 ILL
MLR426
ILL
drum brakes - yellow zinc di-chromate
disc brakes - yellow zinc di-chromate - but painted gloss black with the power brake booster
Yes Bill and I painted my bendix booster and master cylinder set up on my 71 hemi cuda clone just like the factory did it as an assembly and the judges at the Nats deducted points for not having a plated master cylinder cap. The master cylinder caps were painted just like the rest of the assembly. But we have no recourse on final judgement calls ?
logan426
[Re: BradD]
#856934
11/18/10 03:02 PM
11/18/10 03:02 PM
Posts: 21,483 It's a dry heat
gtx6970
It's a dry heat
Brad
Although similar in appearence Hemi Boosters are unique to hemi cars. and I'm 99% sure the brackets and all were painted as an assembly with the booster.
[Re: MLR426]
#856936
11/18/10 03:10 PM
11/18/10 03:10 PM
gtx6970
It's a dry heat
Ha, Beat ya But I agree with you if that matters Also,,,,,I think the non hemi 67 B-body disc brake cars use a similar style if not the same booster and brackets as hemi cars
[Re: gtx6970]
#856937
11/18/10 04:03 PM
11/18/10 04:03 PM
Posts: 4,799 ILL
MLR426
ILL
[Re: JohnRR]
#856939
11/18/10 04:50 PM
11/18/10 04:50 PM
Posts: 2,483 Minneapolis, MN
hemi70se
Minneapolis, MN
Ha, Beat ya
almost , non hemi cars didn't have a bracket in the rear , the booster mounts directly to the firewall reinforcement plate .
Sorry John... but he is correct. I have seen many ( and removed them ) on non-hemi 67 cars with disc brakes. FYI to all... those 66-67 Hemi boosters have a different looking vacuum port. It has 2 pc. lock nut looking connection rather than a grommet and push in valve. To answer than OP.... the hemi units were painted as a complete assembly with the linkage and all hanging off the back. As far as the Nats judges not knowing squat... I can believe that! When I had my 70 Hemi POWER DRUM brake Charger judged at Carlisle they said my painted drum MC was incorrect. They thought that ALL drum brake cars should be natural metal. Which is true, EXCEPT for POWER BRAKE HEMI CARS.
[Re: JohnRR]
#856940
11/18/10 05:39 PM
11/18/10 05:39 PM
gtx6970
It's a dry heat
Ha, Beat ya
ooooahhhh
[Re: hemi70se]
#856942
11/19/10 11:18 AM
11/19/10 11:18 AM
Posts: 75,083 U.S.S.A.
JohnRR
U.S.S.A.
Ha, Beat ya
Didn't realize that 67 was different than the 68-70 Disc brake , non hemi cars
[Re: JohnRR]
#856943
11/19/10 11:26 AM
11/19/10 11:26 AM
BradD
Thanks guys. I forgot about the larger stud size on Hemi boosters. Maybe this thread should go to the Tech Archives.
Brad
[Re: Dr V]
#856945
11/19/10 10:38 PM
11/19/10 10:38 PM
Posts: 21,533 N.E. OHIO, USA
A12
N.E. OHIO, USA
Can I ask about a '69 440 GTX with power disc brakes...............because I have a photo of the engine bay that I'm pretty sure was never touched (painted) and it has the power brake master cylinder and lid painted black like you stated. Note the brake lines exit the master cylinder on the passenger's side which I'm told is correct for a power disc '69 B-body at least?
Is all black correct for a '69 GTX 440 (4-speed if that even matters)? thanks.
